Configures the timer to be used for the TIME$ and DATE$ variables.
CONFIG CLOCK = soft | USER [, GOSUB = SECTIC] [,RTC=rtc] [,RTC32=rtc32]
Soft |
Use SOFT for using the software based clock routines. Use USER to write/use your own code in combination with an I2C clock chip for example. |
Sectic |
This option allows to jump to a user routine with the label sectic.
Since the interrupt occurs every second you may handle various tasks in the sectic label. It is important that you use the name SECTIC and that you return with a RETURN statement from this label.
The usage of the optional SECTIC routine will use 30 bytes of the hardware stack. This option only works with the SOFT clock mode. It does not work in USER mode. |
RTC |
This option is only available for processors with an RTC (XMEGA). This option sets the RTC clock source.
Valid parameters are : 1KHZ_INT32KHZ_ULP 1 kHz from internal 32 kHz ULP 1KHZ_32KHZ_CRYSTOSC 1 kHz from 32 kHz Crystal Oscillator on TOSC 1KHZ_INT32KHZ_RCOSC 1 kHz from internal 32 kHz RC Oscillator 32KHZ_32KHZ_CRYSTOSC 32 kHz from 32 kHz Crystal Oscillator on TOSC
The 1KHz clocks will load the PER register with 1000-1 and the 32 KHz clock will load PER with a value of 32768-1. The overflow mode is used and you can use the compare overflow if required.
Do not forget to enable the 32 KHz oscillator and the interrupts as shown in the Xmega example. |
RTC32 |
This option is available for few XMEGA chips. You can use it instead of the RTC. You can not use both RTC and RTC32 together. RTC32 only accepts one value : 32KHZ_32KHZ_CRYSTOSC This also means that you must use an external 32 KHz crystal oscillator. |
When you use the CONFIG CLOCK directive the compiler will DIM the following variables automatic : _sec , _min , _hour, _day , _month , _year
The variables TIME$ and DATE$ will also be dimensioned. These are special variables since they are treated different. See TIME$ and DATE$.
The _sec, _min and other internal variables can be changed by the user too.
But of course changing their values will change the DATE$/TIME$ variables.
The compiler also creates an ISR that gets updates once a second. This works only for the 8535, M163 and M103 and M603, or other AVR chips that have a timer that can work in asynchrony mode.
For the 90S8535, timer2 is used. It can not be used my the user anymore! This is also true for the other chips async timer.
Notice that you need to connect a 32768 Hz crystal in order to use the timer in async mode, the mode that is used for the clock timer.
When you choose the USER option, only the internal variables are created. With the USER option you need to write the clock code yourself.
See the datetime.bas example that shows how you can use a DS1307 clock chip for the date and time generation.
Numeric Values to calculate with Date and Time:
| • | SecOfDay: (Type LONG) Seconds elapsed since Midnight. 00:00:00 start with 0 to 85399 at 23:59:59. |
| • | SysSec: (Type LONG) Seconds elapsed since begin of century (at 2000-01-01!). 00:00:00 at 2000-01-01 start with 0 to 2147483647 (overflow of LONG-Type) at 2068-01-19 03:14:07 |
| • | DayOfYear: (Type WORD) Days elapsed since first January of the current year. |
| • | First January start with 0 to 364 (365 in a leap year) |
| • | SysDay: (Type WORD) Days elapsed since begin of century (at 2000-01-01!). 2000-01-01 starts with 0 to 36524 at 2099-12-31 |
| • | DayOfWeek: (Type Byte) Days elapsed since Monday of current week. Monday start with 0 to Sunday = 6 |
With the numeric type calculations with Time and date are possible. Type 1 (discrete Bytes) and 2 (Strings) can be converted to an according numeric value. Than Seconds (at SecOfDay and SysSec) or Days (at DayOfYear, SysDay), can be added or subtracted. The Result can be converted back.
TIME$ , DATE$ , CONFIG DATE
The following ASM routines are called from datetime.lib
_soft_clock. This is the ISR that gets called once per second.
'name : megaclock.bas
'purpose : shows the new TIME$ and DATE$ reserved variables
'micro : Mega103
'suited for demo : yes
'commercial addon needed : no
'[configure LCD]
'[now init the clock]
Config Date = Mdy , Separator = / ' ANSI-Format
'The format is MM/DD/YY
Date$ = "11/11/00"
'You may not use 1:2:3 !! adding support for this would mean overhead
Time$ = "02:20:00"
'clear the LCD display
Cls
Home 'cursor home
_day = 1
Xmega Sample
' (c) 1995-2010, MCS
' xm128-RTC.bas
' This sample demonstrates the Xmega128A1 RTC
$regfile = "xm128a1def.dat"
$crystal = 32000000
$hwstack = 64
$swstack = 64
$framesize = 64
$lib "xmega.lib"
$external _xmegafix_clear
$external _xmegafix_rol_r1014
Config Portb = Output
'First Enable The Osc Of Your Choice , make sure to enable 32 KHz clock or use an external 32 KHz clock
Config Osc = Enabled , 32mhzosc = Enabled , 32khzosc = Enabled
' For the CLOCK we use the RTC so make sure the 32 KHZ osc is enabled!!!
'configure the systemclock
Open "COM1:" For Binary As #1
Config Clock = Soft , Rtc = 1khz_int32khz_ulp ' we select the internal 1 KHz clock from the 32KHz internal oscillator
'the following clocks can be used to clock the RTC
' 1KHZ_INT32KHZ_ULP 1 kHz from internal 32 kHz ULP
' 1KHZ_32KHZ_CRYSTOSC 1 kHz from 32 kHz Crystal Oscillator on TOSC
' 1KHZ_INT32KHZ_RCOSC 1 kHz from internal 32 kHz RC Oscillator
' 32KHZ_32KHZ_CRYSTOSC 32 kHz from 32 kHz Crystal Oscillator on TOSC
Config Priority = Static , Vector = Application , Lo = Enabled ' the RTC uses LO priority interrupts so these must be enabled !!!
Enable Interrupts ' as usual interrupts must be enabled
Print Time$ ' print the time
Waitms 1000
Sectic:
Toggle Portb 'optional toggle some leds when using the gosub=sectic option
