Internal variable that holds the date.
DATE$ = "mm/dd/yy"
var = DATE$
The DATE$ variable is used in combination with the CONFIG CLOCK directive.
The CONFIG CLOCK statement will use the TIMER0 or TIMER2 in asynchrone mode to create an interrupt that occurs every second. In this interrupt routine the _Sec, _Min and _Hour variables are updated. The _dat, _month and _year variables are also updated. The date format is in the same format as in VB.
When you assign DATE$ to a string variable these variables are assigned to the DATE$ variable.
When you assign the DATE$ variable with a constant or other variable, the _day, _month and _year variables will be changed to the new date.
The only difference with VB is that all data must be provided when assigning the date. This is done for minimal code. You can change this behavior of course.
The async timer is only available in the M103, 90S8535, M163 and M32(3), Mega128, Mega64, Mega8. For other chips it will not work.
As new chips are launched by Atmel, and support is added by MCS, the list above might not be complete. It is intended to serve as an example for chips with a timer that can be used in asynchrone mode. So when your micro has a timer that can be used in asynchrone mode, it should work.
Do not confuse DATE$ with the DATE function.
The following ASM routines are called.
When assigning DATE$ : _set_date (calls _str2byte)
When reading DATE$ : _make_dt (calls _byte2str)
TIME$ , CONFIG CLOCK , DATE
'name : megaclock.bas
'purpose : shows the new TIME$ and DATE$ reserved variables
'micro : Mega103
'suited for demo : yes
'commercial addon needed : no
'[configure LCD]
'[now init the clock]
Config Date = Mdy , Separator = / ' ANSI-Format
'The format is MM/DD/YY
Date$ = "11/11/00"
'You may not use 1:2:3 !! adding support for this would mean overhead
Time$ = "02:20:00"
'clear the LCD display
Cls
Home 'cursor home
_day = 1
