TIME$
Top  Previous  Next
Internal variable that holds the time.
TIME$ = "hh:mm:ss"
var = TIME$
The TIME$ variable is used in combination with the CONFIG CLOCK and CONFIG DATE directive.
The CONFIG CLOCK statement will use the TIMER0 or TIMER2 in async mode to create a 1 second interrupt. In this interrupt routine the _Sec, _Min and _Hour variables are updated. The time format is 24 hours format.
When you assign TIME$ to a string variable these variables are assigned to the TIME$ variable.
When you assign the TIME$ variable with a constant or other variable, the _sec, _Hour and _Min variables will be changed to the new time.
The only difference with VB is that all digits must be provided when assigning the time. This is done for minimal code. You can change this behavior of course.
The async timer is only available in the M103, 90S8535, M163 and M32(3), Mega128, Mega64, Mega8. For other chips it will not work.
noticeAs new chips are launched by Atmel, and support is added by MCS, the list above might not be complete. It is intended to serve as an example for chips with a timer that can be used in asynchrone mode. So when your micro has a timer that can be used in asynchrone mode, it should work.
important Do not confuse DATE$ with the DATE function.
When assigning TIME$ : _set_time (calls _str2byte)
When reading TIME$ : _make_dt (calls _byte2str)
DATE$ , CONFIG CLOCK , CONFIG DATE
See the sample of DATE$
