Configure the Format of the Date String for Input to and Output from BASCOM – Date functions
CONFIG DATE = DMY , Separator = char
DMY |
The Day, month and year order. Use DMY, MDY or YMD. |
Char |
The character used to separate the day, month and year.
Old syntax : / , - or . (dot).
Preferred new syntax : MINUS, SLASH or DOT.
Example: Config Date = DMY, SEPARATOR=MINUS |
The following table shows the common formats of date and the associated statements.
Country |
Format |
Statement |
American |
mm/dd/yy |
Config Date = MDY, Separator = SLASH |
ANSI |
yy.mm.dd |
Config Date = YMD, Separator = DOT |
Britisch/French |
dd/mm/yy |
Config Date = DMY, Separator = SLASH |
German |
dd.mm.yy |
Config Date = DMY, Separator = DOT |
Italian |
dd-mm-yy |
Config Date = DMY, Separator = MINUS |
Japan/Taiwan |
yy/mm/dd |
Config Date = YMD, Separator = SLASH |
USA |
mm-dd-yy |
Config Date = MDY, Separator = MINUS |
When you live in Holland you would use :
CONFIG DATE = DMY, separator = MINUS
This would print 24-04-02 for 24 November 2002.
When you line in the US, you would use :
CONFIG DATE = MDY , separator = SLASH
This would print 04/24/02 for 24 November 2002.
CONFIG CLOCK , DATE TIME functions , DayOfWeek , DayOfYear , SecOfDay , SecElapsed , SysDay , SysSec , SysSecElapsed , Time , Date
'name : megaclock.bas
'purpose : shows the new TIME$ and DATE$ reserved variables
'micro : Mega103
'suited for demo : yes
'commercial addon needed : no
'[configure LCD]
'[now init the clock]
Config Date = Mdy , Separator = SLASH ' ANSI-Format
'The format is MM/DD/YY
Date$ = "11/11/00"
'You may not use 1:2:3 !! adding support for this would mean overhead
Time$ = "02:20:00"
'clear the LCD display
Cls
Home 'cursor home
_day = 1
