With this option you can modify the simulator settings.
OPTION |
DESCRIPTION |
Use integrated simulator |
Set this option to use BASCOM’s simulator. You can also use AVR Studio by clearing this option. |
Run simulator after compilation |
Run the selected simulator after a successful compilation. |
Program |
The path with the program name of the external simulator. |
Parameter |
The parameter to pass to the program. {FILE}.OBJ will supply the name of the current program with the extension .OBJ to the simulator. |
