The following table shows the reserved BASCOM statements or characters.
$BAUD , $BAUD1 , $BOOT , $CRYSTAL ,$DATA ,$DBG ,$DEFAULT , $END , $EEPROM , $EXTERNAL , $INCLUDE , $LCD , $LCDRS , $LCDPUTCTRL , $LCDPUTDATA , $LCDVFO , $LIB ,$MAP ,$REGFILE ,$SERIALINPUT ,$SERIALINPUT1, $SERIALINPUT2LCD , $SERIALOUTPUT , $SERIALOUTPUT1 ,
$TINY ,$WAITSTATE ,$XRAMSIZE , $XRAMSTART
1WRESET ,1WREAD ,1WWRITE
ACK ,ABS ,ALIAS ,AND ,ACOS ,AS , ASC , ASIN , AT , ATN, ATN2
BAUD, BCD , BIN , BIN2GRAY , BINVAL , BIT , BITWAIT , BLINK , BOOLEAN , BYTE , BYVAL
CALL , CAPTURE1 , CASE , CHECKSUM , CHR , CIRCLE , CLS , CLOSE , COMPARE1x , CONFIG , CONST , COS , COSH , COUNTER , COUNTERx ,
CPEEK , CPEEKH , CRC8 , CRC16 , CRC32 , CRYSTAL , CURSOR
DATA, DATE$, DBG , DEBOUNCE , DECR , DECLARE , DEFBIT , DEFBYTE , DEFLNG , DEFWORD , DEG2RAD , DEGSNG , DEFLCDCHAR, DEFINT ,
DEFWORD , DELAY , DIM , DISABLE , DISKSIZE , DISKFREESIZE , DISPLAY , DO , DOUBLE, DOWNTO , DTMFOUT
ELSE, ELSEIF, ENABLE, END, EOF, ERAM, ERASE, ERR, EXIT, EXP, EXTERNAL, FIX, FLUSH, FOR, FOURTH, FOURTHLINE, FREEFILE, FUNCTION
GATE, GET, GETADC, GETKBD, GETATKBD , GETRC5, GLCDDATA , GLCDCMD, GOSUB, GOTO, GRAY2BIN
HEXVAL,HIGH, HOME
I2CINIT, I2CRECEIVE, I2CSEND, I2CSTART, I2CSTOP, I2CRBYTE, I2CWBYTE, IDLE, IF , INCR , INKEY , INP , INPUT , INPUTBIN , INPUTHEX ,
INT, INT0, INT1, INTEGER, INTERNAL, INSTR, IS, ISCHARWAITING
LCASE, LCD, LCDAT, LEFT, LEFT, LEN, LINE, LOAD, LOADLABEL, LOC , LOF , LOCAL, LOCATE, LOG , LOG10 , LONG, LOOKUP, LOOKUPSTR,
LOOP, LTRIM, LOOKDOWN, LOW, LOWER, LOWERLINE
MAKEBCD, MAKEDEC, MAKEINT, MID, MIN, MAX, MOD, MODE
NACK, NEXT, NOBLINK, NOSAVE, NOT
OFF, ON, OR, OUT, OUTPUT
PEEK, POKE, PORTx, POWER, POWERDOWN, PRINT, PRINTBIN, PULSEOUT, PUT, PWM1x, RAD2DEG, RC5SEND, RC6SEND, READ, READEEPROM
REM, RESET, RESTORE, RETURN, RIGHT, RIGHT, ROTATE, ROUND, RTRIM
SEEK, SELECT, SERIAL, SET, SERIN , SEROUT, SETFONT, SGN, SHIFT, SHIFTLCD, SHIFTCURSOR,SHIFTIN , SHIFTOUT , SHOWPIC, SHOWPICE,
SIN, SINH , SONYSEND , SOUND , SPACE, SPC , SPIINIT , SPIIN , SPIMOVE , SPIOUT , START , STEP , STR , STRING , STOP , SUB , SWAP , SQR
TAN , TANH , THEN , TIME$ , THIRD , THIRDLINE , TIMERx , TO , TRIM , TYPE
UCASE, UNTIL , UPPER , UPPERLINE
VAL, VARPTR
WAIT, WAITKEY, WAITMS , WAITUS , WATCHDOG , WRITEEEPROM , WEND , WHILE ,WORD
XOR, XRAM
