The following table lists errors that can occur.
Error |
Description |
1 |
Unknown statement |
2 |
Unknown structure EXIT statement |
3 |
WHILE expected |
4 |
No more space for IRAM BIT |
5 |
No more space for BIT |
6 |
. expected in filename |
7 |
IF THEN expected |
8 |
BASIC source file not found |
9 |
Maximum 128 aliases allowed |
10 |
Unknown LCD type |
11 |
INPUT, OUTPUT, 0 or 1 expected |
12 |
Unknown CONFIG parameter |
13 |
CONST already specified |
14 |
Only IRAM bytes supported |
15 |
Wrong data type |
16 |
Unknown Definition |
17 |
9 parameters expected |
18 |
BIT only allowed with IRAM or SRAM |
19 |
STRING length expected (DIM S AS STRING * 12 ,for example) |
20 |
Unknown DATA TYPE |
21 |
Out of IRAM space |
22 |
Out of SRAM space |
23 |
Out of XRAM space |
24 |
Out of EPROM space |
25 |
Variable already dimensioned |
26 |
AS expected |
27 |
parameter expected |
28 |
IF THEN expected |
29 |
SELECT CASE expected |
30 |
BIT's are GLOBAL and can not be erased |
31 |
Invalid data type |
32 |
Variable not dimensioned |
33 |
GLOBAL variable can not be ERASED |
34 |
Invalid number of parameters |
35 |
3 parameters expected |
36 |
THEN expected |
37 |
Invalid comparison operator |
38 |
Operation not possible on BITS |
39 |
FOR expected |
40 |
Variable can not be used with RESET |
41 |
Variable can not be used with SET |
42 |
Numeric parameter expected |
43 |
File not found |
44 |
2 variables expected |
45 |
DO expected |
46 |
Assignment error |
47 |
UNTIL expected |
50 |
Value doesn't fit into INTEGER |
51 |
Value doesn't fit into WORD |
52 |
Value doesn't fit into LONG |
60 |
Duplicate label |
61 |
Label not found |
62 |
SUB or FUNCTION expected first |
63 |
Integer or Long expected for ABS() |
64 |
, expected |
65 |
device was not OPEN |
66 |
device already OPENED |
68 |
channel expected |
70 |
BAUD rate not possible |
71 |
Different parameter type passed then declared |
72 |
Getclass error. This is an internal error. |
73 |
Printing this FUNCTION not yet supported |
74 |
80 |
Code does not fit into target chip |
81 |
Use HEX(var) instead of PRINTHEX |
82 |
Use HEX(var) instead of LCDHEX |
85 |
Unknown interrupt source |
86 |
Invalid parameter for TIMER configuration |
87 |
ALIAS already used |
88 |
0 or 1 expected |
89 |
Out of range : must be 1-4 |
90 |
Address out of bounds |
91 |
INPUT, OUTPUT, BINARY, or RANDOM expected |
92 |
LEFT or RIGHT expected |
93 |
94 |
Too many bits specified |
95 |
Falling or rising expected for edge |
96 |
Pre scale value must be 1,8,64,256 or 1024 |
97 |
SUB or FUNCTION must be DECLARED first |
98 |
SET or RESET expected |
99 |
TYPE expected |
100 |
No array support for IRAM variables |
101 |
Can't find HW-register |
102 |
Error in internal routine |
103 |
= expected |
104 |
LoadReg error |
105 |
StoreBit error |
106 |
Unknown register |
107 |
LoadnumValue error |
108 |
Unknown directive in device file |
109 |
= expected in include file for .EQU |
110 |
Include file not found |
111 |
SUB or FUNCTION not DECLARED |
112 |
SUB/FUNCTION name expected |
113 |
SUB/FUNCTION already DECLARED |
114 |
LOCAL only allowed in SUB or FUNCTION |
115 |
#channel expected |
116 |
Invalid register file |
117 |
Unknown interrupt |
126 |
NEXT expected. |
129 |
( or ) missing. |
200 |
.DEF not found |
201 |
Low Pointer register expected |
202 |
.EQU not found, probably using functions that are not supported by the selected chip |
203 |
Error in LD or LDD statement |
204 |
Error in ST or STD statement |
205 |
} expected |
206 |
Library file not found |
207 |
Library file already registered |
210 |
Bit definition not found |
211 |
External routine not found |
212 |
LOW LEVEL, RISING or FALLING expected |
213 |
String expected for assignment |
214 |
Size of XRAM string 0 |
215 |
Unknown ASM mnemonic |
216 |
CONST not defined |
217 |
No arrays allowed with BIT/BOOLEAN data type |
218 |
Register must be in range from R16-R31 |
219 |
INT0-INT3 are always low level triggered in the MEGA |
220 |
Forward jump out of range |
221 |
Backward jump out of range |
222 |
Illegal character |
223 |
* expected |
224 |
Index out of range |
225 |
() may not be used with constants |
226 |
Numeric of string constant expected |
227 |
SRAM start greater than SRAM end |
228 |
DATA line must be placed after the END statement |
229 |
End Sub or End Function expected |
230 |
You can not write to a PIN register |
231 |
TO expected |
232 |
Not supported for the selected micro |
233 |
READ only works for normal DATA lines, not for EPROM data |
234 |
') block comment expected first |
235 |
'( block comment expected first |
236 |
Value does not fit into byte |
238 |
Variable is not dimensioned as an array |
239 |
Invalid code sequence because of AVR hardware bug |
240 |
END FUNCTION expected |
241 |
END SUB expected |
242 |
Source variable does not match the target variable |
243 |
Bit index out of range for supplied data type |
244 |
Do not use the Y pointer |
245 |
No arrays supported with IRAM variable |
246 |
No more room for .DEF definitions |
247 |
. expected |
248 |
BYVAL should be used in declaration |
249 |
ISR already defined |
250 |
GOSUB expected |
251 |
Label must be named SECTIC |
252 |
Integer or Word expected |
253 |
ERAM variable can not be used |
254 |
Variable expected |
255 |
Z or Z+ expected |
256 |
Single expected |
257 |
"" expected |
258 |
SRAM string expected |
259 |
- not allowed for a byte |
260 |
Value larger than string length |
261 |
Array expected |
262 |
ON or OFF expected |
263 |
Array index out of range |
264 |
Use ECHO OFF and ECHO ON instead |
265 |
offset expected in LDD or STD like Z+1 |
266 |
TIMER0, TIMER1 or TIMER2 expected |
267 |
Numeric constant expected |
268 |
Param must be in range from 0-3 |
269 |
END SELECT expected |
270 |
Address already occupied |
322 |
Data type not supported with statement |
323 |
Label too long |
324 |
Chip not supported by I2C slave library |
325 |
Pre-scale value must be 1,8,32,128,256 or 1024 |
326 |
#ENDIF expected |
327 |
Maximum size is 255 |
328 |
Not valid for SW UART |
329 |
FileDateTime can only be assigned to a variable |
330 |
Maximum value for OUT is &H3F |
332 |
$END ASM expected |
334 |
') blockcomment end expected |
335 |
Use before DIM statements |
336 |
Could not set specified CLOCK value |
999 |
DEMO/BETA only supports 4096 bytes of code |
9999 |
I hope you do not see this one. |
Other error codes are internal ones. Please report them when you get them.
