Assembler mnemonics
Top  Previous  Next
BASCOM supports the mnemonics as defined by Atmel.
The Assembler accepts mnemonic instructions from the instruction set.
A summary of the instruction set mnemonics and their parameters is given here. For a detailed description of the Instruction set, refer to the AVR Data Book.
Mnemonics
Operands
Description
Operation
Flags
Clock
ARITHMETIC AND LOGIC INSTRUCTIONS
ADD
Rd, Rr
Add without Carry
Rd = Rd + Rr
Z,C,N,V,H
1
ADC
Rd, Rr
Add with Carry
Rd = Rd + Rr + C
Z,C,N,V,H
1
SUB
Rd, Rr
Subtract without Carry
Rd = Rd – Rr
Z,C,N,V,H
1
SUBI
Rd, K
Subtract Immediate
Rd = Rd – K
Z,C,N,V,H
1
SBC
Rd, Rr
Subtract with Carry
Rd = Rd - Rr - C
Z,C,N,V,H
1
SBCI
Rd, K
Subtract Immediate with Carry
Rd = Rd - K - C
Z,C,N,V,H
1
AND
Rd, Rr
Logical AND
Rd = Rd · Rr
Z,N,V
1
ANDI
Rd, K
Logical AND with Immediate
Rd = Rd · K
Z,N,V
1
OR
Rd, Rr
Logical OR
Rd = Rd v Rr
Z,N,V
1
ORI
Rd, K
Logical OR with Immediate
Rd = Rd v K
Z,N,V
1
EOR
Rd, Rr
Exclusive OR
Rd = Rd Å Rr
Z,N,V
1
COM
Rd
Ones Complement
Rd = $FF - Rd
Z,C,N,V
1
NEG
Rd
Twos Complement
Rd = $00 - Rd
Z,C,N,V,H
1
SBR
Rd,K
Set Bit(s) in Register
Rd = Rd v K
Z,N,V
1
CBR
Rd,K
Clear Bit(s) in Register
Rd = Rd · ($FFh - K)
Z,N,V
1
INC
Rd
Increment
Rd = Rd + 1
Z,N,V
1
DEC
Rd
Decrement
Rd = Rd - 1
Z,N,V
1
TST
Rd
Test for Zero or Minus
Rd = Rd · Rd
Z,N,V
1
CLR
Rd
Clear Register
Rd = Rd Å Rd
Z,N,V
1
SER
Rd
Set Register
Rd = $FF
None
1
ADIW
Adiw r24, K6
Rdl, K6
Add Immediate to Word
Rdh:Rdl = Rdh:Rdl + K
Z,C,N,V,S
2
SBIW
Sbiw R24,K6
Rdl, K6
Subtract Immediate from Word
Rdh:Rdl = Rdh:Rdl - K
Z,C,N,V,S
2
MUL
Rd,Rr
Multiply Unsigned
R1, R0 = Rd * Rr
C
2 *
BRANCH INSTRUCTIONS
RJMP
K
Relative Jump
PC = PC + k + 1
None
2
IJMP
Indirect Jump to (Z)
PC = Z
None
2
JMP
K
Jump
PC = k
None
3
RCALL
K
Relative Call Subroutine
PC = PC + k + 1
None
3
ICALL
Indirect Call to (Z)
PC = Z
None
3
CALL
K
Call Subroutine
PC = k
None
4
RET
Subroutine Return
PC = STACK
None
4
RETI
Interrupt Return
PC = STACK
I
4
CPSE
Rd,Rr
Compare, Skip if Equal
if (Rd = Rr) PC = PC + 2 or 3
None
1 / 2
CP
Rd,Rr
Compare
Rd - Rr
Z,C,N,V,H,
1
CPC
Rd,Rr
Compare with Carry
Rd - Rr - C
Z,C,N,V,H
1
CPI
Rd,K
Compare with Immediate
Rd - K
Z,C,N,V,H
1
SBRC
Rr, b
Skip if Bit in Register Cleared
If (Rr(b)=0) PC = PC + 2 or 3
None
1 / 2
SBRS
Rr, b
Skip if Bit in Register Set
If (Rr(b)=1) PC = PC + 2 or 3
None
1 / 2
SBIC
P, b
Skip if Bit in I/O Register Cleared
If(I/O(P,b)=0) PC = PC + 2 or 3
None
2 / 3
SBIS
P, b
Skip if Bit in I/O Register Set
If(I/O(P,b)=1) PC = PC + 2 or 3
None
2 / 3
BRBS
s, k
Branch if Status Flag Set
if (SREG(s) = 1) then PC=PC+k + 1
None
1 / 2
BRBC
s, k
Branch if Status Flag Cleared
if (SREG(s) = 0) then PC=PC+k + 1
None
1 / 2
BREQ
K
Branch if Equal
if (Z = 1) then PC = PC + k + 1
None
1 / 2
BRNE
K
Branch if Not Equal
if (Z = 0) then PC = PC + k + 1
None
1 / 2
BRCS
K
Branch if Carry Set
if (C = 1) then PC = PC + k + 1
None
1 / 2
BRCC
K
Branch if Carry Cleared
if (C = 0) then PC = PC + k + 1
None
1 / 2
BRSH
K
Branch if Same or Higher
None
1 / 2
BRLO
K
Branch if Lower
None
1 / 2
BRMI
K
Branch if Minus
if (N = 1) then PC = PC + k + 1
None
1 / 2
BRPL
K
Branch if Plus
if (N = 0) then PC = PC + k + 1
None
1 / 2
BRGE
K
Branch if Greater or Equal, Signed
if (N V= 0) then PC = PC+ k + 1
None
1 / 2
BRLT
K
Branch if Less Than, Signed
if (N V= 1) then PC = PC + k + 1
None
1 / 2
BRHS
K
Branch if Half Carry Flag Set
if (H = 1) then PC = PC + k + 1
None
1 / 2
BRHC
K
Branch if Half Carry Flag Cleared
if (H = 0) then PC = PC + k + 1
None
1 / 2
BRTS
K
Branch if T Flag Set
if (T = 1) then PC = PC + k + 1
None
1 / 2
BRTC
K
Branch if T Flag Cleared
if (T = 0) then PC = PC + k + 1
None
1 / 2
BRVS
K
Branch if Overflow Flag is Set
if (V = 1) then PC = PC + k + 1
None
1 / 2
BRVC
K
Branch if Overflow Flag is Cleared
if (V = 0) then PC = PC + k + 1
None
1 / 2
BRIE
K
Branch if Interrupt Enabled
if ( I = 1) then PC = PC + k + 1
None
1 / 2
BRID
K
Branch if Interrupt Disabled
if ( I = 0) then PC = PC + k + 1
None
1 / 2
DATA TRANSFER INSTRUCTIONS
MOV
Rd, Rr
Copy Register
Rd = Rr
None
1
LDI
Rd, K
Load Immediate
Rd = K
None
1
LDS
Rd, k
Load Direct
Rd = (k)
None
2
LD
Rd, X
Load Indirect
Rd = (X)
None
2
LD
Rd, X+
Load Indirect and Post-Increment
Rd = (X), X = X + 1
None
2
LD
Rd, -X
Load Indirect and Pre-Decrement
X = X - 1, Rd =(X)
None
2
LD
Rd, Y
Load Indirect
Rd = (Y)
None
2
LD
Rd, Y+
Rd = (Y), Y = Y + 1
None
2
LD
Rd, -Y
Y = Y - 1, Rd = (Y)
None
2
LDD
Rd,Y+q
Load Indirect with Displacement
Rd = (Y + q)
None
2
LD
Rd, Z
Load Indirect
Rd = (Z)
None
2
LD
Rd, Z+
Rd = (Z), Z = Z+1
None
2
LD
Rd, -Z
Z = Z - 1, Rd = (Z)
None
2
LDD
Rd, Z+q
Rd = (Z + q)
None
2
STS
k, Rr
Store Direct
(k) = Rr
None
2
ST
X, Rr
Store Indirect
(X) = Rr
None
2
ST
X+, Rr
Store Indirect and Post-Increment
(X) = Rr, X = X + 1
None
2
ST
-X, Rr
Store Indirect and Pre-Decrement
X = X - 1, (X) = Rr
None
2
ST
Y, Rr
Store Indirect
(Y) = Rr
None
2
ST
Y+, Rr
(Y) = Rr, Y = Y + 1
None
2
ST
-Y, Rr
Y = Y - 1, (Y) = Rr
None
2
STD
Y+q,Rr
Store Indirect with Displacement
(Y + q) = Rr
None
2
ST
Z, Rr
Store Indirect
(Z) = Rr
None
2
ST
Z+, Rr
(Z) = Rr, Z = Z + 1
None
2
ST
-Z, Rr
Z = Z - 1, (Z) = Rr
None
2
STD
Z+q,Rr
(Z + q) = Rr
None
2
LPM
Load Program Memory
R0 =(Z)
None
3
IN
Rd, P
In Port
Rd = P
None
1
OUT
P, Rr
Out Port
P = Rr
None
1
PUSH
Rr
Push Register on Stack
STACK = Rr
None
2
POP
Rd
Pop Register from Stack
Rd = STACK
None
2
BIT AND BIT-TEST INSTRUCTIONS
LSL
Rd
Logical Shift Left
Rd(n+1) =Rd(n),Rd(0)= 0,C=Rd(7)
Z,C,N,V,H
1
LSR
Rd
Logical Shift Right
Rd(n) = Rd(n+1), Rd(7) =0, C=Rd(0)
Z,C,N,V
1
ROL
Rd
Rotate Left Through Carry
Rd(0) =C, Rd(n+1) =Rd(n),C=Rd(7)
Z,C,N,V,H
1
ROR
Rd
Rotate Right Through Carry
Rd(7) =C,Rd(n) =Rd(n+1),C¬Rd(0)
Z,C,N,V
1
ASR
Rd
Arithmetic Shift Right
Rd(n) = Rd(n+1), n=0..6
Z,C,N,V
1
SWAP
Rd
Swap Nibbles
Rd(3..0) « Rd(7..4)
None
1
BSET
S
Flag Set
SREG(s) = 1
SREG(s)
1
BCLR
S
Flag Clear
SREG(s) = 0
SREG(s)
1
SBI
P, b
Set Bit in I/O Register
I/O(P, b) = 1
None
2
CBI
P, b
Clear Bit in I/O Register
I/O(P, b) = 0
None
2
BST
Rr, b
Bit Store from Register to T
T = Rr(b)
T
1
BLD
Rd, b
Bit load from T to Register
Rd(b) = T
None
1
SEC
Set Carry
C = 1
C
1
CLC
Clear Carry
C = 0
C
1
SEN
Set Negative Flag
N = 1
N
1
CLN
Clear Negative Flag
N = 0
N
1
SEZ
Set Zero Flag
Z = 1
Z
1
CLZ
Clear Zero Flag
Z = 0
Z
1
SEI
Global Interrupt Enable
I = 1
I
1
CLI
Global Interrupt Disable
I = 0
I
1
SES
Set Signed Test Flag
S = 1
S
1
CLS
Clear Signed Test Flag
S = 0
S
1
SEV
Set Twos Complement Overflow
V = 1
V
1
CLV
Clear Twos Complement Overflow
V = 0
V
1
SET
Set T in SREG
T = 1
T
1
CLT
Clear T in SREG
T = 0
T
1
SHE
Set Half Carry Flag in SREG
H = 1
H
1
CLH
Clear Half Carry Flag in SREG
H = 0
H
1
NOP
No Operation
None
1
SLEEP
Sleep
None
1
WDR
Watchdog Reset
None
1
* ) Not available in base-line microcontrollers
The Assembler is not case sensitive.
The operands have the following forms:
Rd: R0-R31 or R16-R31 (depending on instruction)
Rr: R0-R31
b: Constant (0-7)
s: Constant (0-7)
P: Constant (0-31/63)
K: Constant (0-255)
k: Constant, value range depending on instruction.
q: Constant (0-63)
Rdl:  R24, R26, R28, R30. For ADIW and SBIW instructions
