Instruct the compiler to generate code for 8-bit LCD displays attached to the data bus.
$LCD = [&H]address
Address |
The address where must be written to, to enable the LCD display and the RS line of the LCD display.
The db0-db7 lines of the LCD must be connected to the data lines D0-D7. (or is 4 bit mode, connect only D4-D7) The RS line of the LCD can be configured with the LCDRS statement.
On systems with external RAM, it makes more sense to attach the LCD to the data bus. With an address decoder, you can select the LCD display. |
Do not confuse $LCD with the LCD statement.
The compiler will create a constant named ___LCD_ADR which you could use in an alternative LCD library.
' (c) 1995-2005 MCS Electronics
' file: LCD.BAS
' demo: LCD, CLS, LOWERLINE, SHIFTLCD, SHIFTCURSOR, HOME
' CURSOR, DISPLAY
'note : tested in bus mode with 4-bit on the STK200
'LCD - STK200
'D4 D4
'D5 D5
'D6 D6
'D7 D7
'WR WR
'E E
'RS RS
'+5V +5V
'GND GND
'V0 V0
' D0-D3 are not connected since 4 bit bus mode is used!
$regfile = "8515def.dat"
$lcd = &HC000
$lcdrs = &H8000
Config Lcdbus = 4
Dim A As Byte
Config Lcd = 16 * 2 'configure lcd screen
'other options are 16 * 2 , 16 * 4 and 20 * 4, 20 * 2 , 16 * 1a
' because it aint need the port pins !
Cls 'clear the LCD display
Wait 1
Wait 1
Wait 1
For A = 1 To 10
Wait 1 'wait a moment
For A = 1 To 10
Lcd "*" 'display this
Lcd "@" 'display this
Cursor On Blink 'show cursor
Display Off 'turn display off
Display On 'turn display on
Thirdline
Lcd "Line 3"
Fourthline
Lcd "Line 4"
Home Fourth
Locate 4 , 1 : Lcd "Line 4"
Wait 1
Deflcdchar 1 , 225 , 227 , 226 , 226 , 226 , 242 , 234 , 228 ' replace ? with number (0-7)
Deflcdchar 0 , 240 , 224 , 224 , 255 , 254 , 252 , 248 , 240 ' replace ? with number (0-7)
Cls 'select data RAM
_temp1 = 1 'value into ACC
