Configures the LCD data bus and overrides the compiler setting.
CONFIG LCDBUS = constant
Constant |
4 for 4-bit operation, 8 for 8-bit mode (default) |
Use this statement together with the $LCD = address statement.
When you use the LCD display in the bus mode the default is to connect all the data lines. With the 4-bit mode, you only have to connect data lines d7-d4.
' (c) 1995-2005 MCS Electronics
' file: LCD.BAS
' demo: LCD, CLS, LOWERLINE, SHIFTLCD, SHIFTCURSOR, HOME
' CURSOR, DISPLAY
'note : tested in bus mode with 4-bit on the STK200
'LCD - STK200
'D4 D4
'D5 D5
'D6 D6
'D7 D7
'WR WR
'E E
'RS RS
'+5V +5V
'GND GND
'V0 V0
' D0-D3 are not connected since 4 bit bus mode is used!
$regfile = "8515def.dat"
$lcd = &HC000
$lcdrs = &H8000
Config Lcdbus = 4
Dim A As Byte
Config Lcd = 16x2 'configure lcd screen
'other options are 16 * 2 , 16 * 4 and 20 * 4, 20 * 2 , 16 * 1a
' because it aint need the port pins !
Cls 'clear the LCD display
Wait 1
Wait 1
Wait 1
For A = 1 To 10
Wait 1 'wait a moment
For A = 1 To 10
Lcd "*" 'display this
Lcd "@" 'display this
Cursor On Blink 'show cursor
Display Off 'turn display off
Display On 'turn display on
Thirdline
Lcd "Line 3"
Fourthline
Lcd "Line 4"
Home Fourth
Locate 4 , 1 : Lcd "Line 4"
Wait 1
Deflcdchar 1 , 225 , 227 , 226 , 226 , 226 , 242 , 234 , 228 ' replace ? with number (0-7)
Deflcdchar 0 , 240 , 224 , 224 , 255 , 254 , 252 , 248 , 240 ' replace ? with number (0-7)
Cls 'select data RAM
_temp1 = 1 'value into ACC
