CONFIG LCD
Top  Previous  Next
Configure the LCD display and override the compiler setting.
CONFIG LCD = LCDtype , CHIPSET=KS077 | Dogm163v5 | DOG163V3 | DOG162V5 | DOG162V3 [,CONTRAST=value]
LCDtype
The type of LCD display used. This can be :
40x4,16x1, 16x2, 16x4, 16x4, 20x2, 20x4, 16x1a or 20x4A.
Default 16x2 is assumed.
Chipset
KS077
Most text based LCD displays use the same chip from Hitachi. But some use the KS077 which is highly compatible but needs an additional function register to be set. This parameter will cause that this register is set when you initialize the display.
CHIPSET
DOGM
The DOGM chip set uses a special function register that need to be set.
The 16 x 2 LCD displays need DOG162V3 for 3V operation or DOG162V5 for 5V operation.
The 16 x 3 LCD displays need DOG163V3 for 3V operation or Dogm163v5 for 5V operation
CONTRAST
The optional contrast parameter is only supported for the EADOG displays. By default a value from the manufacture is used. But you might want to override this value with a custom setting.
When you have a 16x2 display, you don't have to use this statement.
The 16x1a is special. It is used for 2x8 displays that have the address of line 2, starting at location &H8.
The 20xA is also special. It uses the addresses &H00, &H20, &H40 and &H60 for the 4 lines. It will also set a special function register.
The CONFIG LCD can only be used once. You can not dynamic(at run time) change the pins.
When you want to initialize the LCD during run time, you can use the INITLCD statement.
See Also
CONFIG LCDPIN , CONFIG LCDBUS
Example1
'name                     : lcd.bas
'copyright                : (c) 1995-2005, MCS Electronics
'purpose                  : demo: LCD, CLS, LOWERLINE, SHIFTLCD, SHIFTCURSOR, HOME
'                           CURSOR, DISPLAY
'micro                    : Mega8515
$regfile = "m8515.dat"                                     ' specify the used micro
$crystal = 4000000                                         ' used crystal frequency
$baud = 19200                                               ' use baud rate
$sim
'REMOVE the above command for the real program !!
'$sim is used for faster simulation
'note : tested in PIN mode with 4-bit
'These settings are for the STK200 in PIN mode
'Connect only DB4 to DB7 of the LCD to the LCD connector of the STK D4-D7
'Connect the E-line of the LCD to A15 (PORTC.7) and NOT to the E line of the LCD connector
'Connect the RS, V0, GND and =5V of the LCD to the STK LCD connector
Dim A As Byte
Config Lcd = 16x2                                         'configure lcd screen
'other options are 16 * 4 and 20 * 4, 20 * 2 , 16 * 1a
'       use this with uP with external RAM and/or ROM
'       because it aint need the port pins !
Cls                                                       'clear the LCD display
Lcd "Hello world."                                         'display this at the top line
Wait 1
Lowerline                                                 'select the lower line
Wait 1
Lcd "Shift this."                                         'display this at the lower line
Wait 1
For A = 1 To 10
Shiftlcd Right                                         'shift the text to the right
Wait 1                                                   'wait a moment
For A = 1 To 10
Shiftlcd Left                                           'shift the text to the left
Locate 2 , 1                                               'set cursor position
Lcd "*"                                                   'display this
Shiftcursor Right                                         'shift the cursor
Lcd "@"                                                   'display this
Home Upper                                                 'select line 1 and return home
Lcd "Replaced."                                           'replace the text
Cursor Off Noblink                                         'hide cursor
Cursor On Blink                                           'show cursor
Display Off                                               'turn display off
Display On                                                 'turn display on
Thirdline
Lcd "Line 3"
Fourthline
Lcd "Line 4"
Home Third                                                 'goto home on line three
Home Fourth
Home F                                                     'first letteer also works
Locate 4 , 1 : Lcd "Line 4"
Wait 1
Deflcdchar 1 , 225 , 227 , 226 , 226 , 226 , 242 , 234 , 228       ' replace ? with number (0-7)
Deflcdchar 0 , 240 , 224 , 224 , 255 , 254 , 252 , 248 , 240       ' replace ? with number (0-7)
Cls                                                       'select data RAM
Lcd Chr(0) ; Chr(1)                                       'print the special character
_temp1 = 1                                                 'value into ACC
!rCall _write_lcd                                           'put it on LCD
Example2
'                        EADOG-M163.bas
'       Demonstration for EADOG 163 display
'                  (c) 1995-2006, MCS Electronics
$regfile = "M8515.dat"
$crystal = 4000000
'I used the following settings
'Config Lcdpin = Pin , Db4 = Portb.2 , Db5 = Portb.3 , Db6 = Portb.4 , Db7 = Portb.5 , E = Portb.1 , Rs = Portb.0
'CONNECT vin TO 5 VOLT
Config Lcd = 16x3 , Chipset = Dogm163v5                   '16*3 type LCD display
'other options for chipset are DOG163V3 for 3Volt operation
'Config Lcd = 16 * 3 , Chipset = Dogm163v3 , Contrast = &H702       '16*3 type LCD display
'The CONTRAST can be specified when the default value is not what you need
'The EADOG-M162 is also supported :
'Chipset params for the DOGM162 : DOG162V5, DOG162V3
Cls                                                       'Dit maakt het scherm leeg
Locate 1 , 1 : Lcd "Hello World"
Locate 2 , 1 : Lcd "line 2"
Locate 3 , 1 : Lcd "line 3"
