Calls a user routine at startup to perform important initialization functions such as setting ports.
$INITMICRO
This directive will call a label named _INIT_MICRO just after the most important initialization is performed. You can put the _INIT_MICRO routine into your program, or you can put it in a library. Advantage of a library is that it is the same for all programs, and advantage of storing the code into your program is that you can change it for every program. |
It is important that you end the routine with a RETURN as the label is called and expects a return.
The $initmicro can be used to set a port direction or value as it performs before the memory is cleared which can take some mS.
The best solution for a defined logic level at startup remains the usage of pull up/pull down resistors.
See Also
$regfile = "m48def.dat"
$crystal = 4000000
$baud = 19200
$initmicro
Print Version() 'show date and time of compilation
Print Portb
nop
'do not write a complete application in this routine.
'only perform needed init functions
_init_micro:
Config Portb = Output
Portb = 3
