Set the color of a LED using a lookup table.
RB_SETTABLECOLOR LED , Index [, Label]
LED |
The index of the LED of the active channel which color need to be changed. The first LED number is 0. |
Index |
A byte variable or constant that holds the index of the table. The table need to be identified by a label. This is either a user defined label, or a label named RAINBOW_COLORS The table has the R, G, B format. Example:
Rainbow_Colors: ' R , G , B index Data &HFF , &H00 , &H00 'Red 0 Data &H00 , &HFF , &H00 'Green 1 Data &H00 , &H00 , &HFF 'Blue 2 Data &HFF , &HA5 , &H00 'Orange 3 Data &HFF , &HFF , &H00 'Yellow 4 Data &HFF , &H69 , &HB4 'HotPink 5 |
Label |
The label name of the table. This is an optional value. If the label name is not specified, the name RAINBOW_COLORS will be used. |
CONFIG RAINBOW , RB_ADDCOLOR, RB_ANDCOLOR, RB_ORCOLOR, RB_SUBCOLOR, RB_CLEARSTRIPE , RB_CLEARCOLORS , RB_FILL , RB_FILLCOLORS , RB_FILLSTRIPE , RB_SELECTCHANNEL, RB_SEND, RB_SETCOLOR , RB_SWAPCOLOR , RB_ROTATELEFT, RB_ROTATERIGHT, RB_SHIFTLEFT, RB_SHIFTRIGHT , RB_CHANGEPIN , RB_GETCOLOR , RB_LOOKUPCOLOR , RB_COPY , RB_COLOR
' rainbow_ws2812_Trafficlights.bas
' This example simulates two simple Trafficlights.
' It shows how switch between two Stripes with just one defined Rainbow.
' The active output gets changed by the RB_ChangePin statement.
' Thus the use of memory is small.
Following situation:
The one way route from the Weststreet to Nothstreet and vice versa is the main route
and cars on these roads have priority.The corresponding light will show green light normally.
In our simple world, every five seconds a car wants to drive from the Eaststreet to the Northstreet.
Thus, the trafficflow from the main street has to stop, to let the cars pass.
' Northstreet
' | | ooo
' EastStreet
WestStreet |
' ooo
$Regfile = "m88pdef.dat"
$Crystal=8000000
$hwstack=40
$swstack=16
$framesize=32
'We use just one Channel for both Trafficlights, cause LED stripes are static
Config RAINBOW= 1, RB0_LEN=3, RB0_PORT=PORTB,rb0_pin=0
Rb_SelectChannel 0 'we use the defined Channel
'Port+Pin combinations, formed to a word
Const MainStreet_0 = (((varptr(portb) + &H20) *256) OR PB0)
Const EastStreet_1 = (((varptr(portb) + &H20) *256) OR PB1)
'----[MAIN]---------------------------------------------------------------------
Dim PortPin as Word
Dim Street as Byte 'selects the current PortPin cofiguration
Const Mainstreet = 0
Const Eaststreet = 1
'Index for LED and colors also
Const Red = 0
Const Yellow = 1
Const Green = 2
Gosub inital_state
Gosub Wait_for_car
'Trafficlight turns to Red
Street = Mainstreet
Gosub Turn_to_Red
'Trafficlight turns to green
Street = Eaststreet
Gosub Turn_to_green
Gosub Wait_for_car 'let some cars passing
Gosub Turn_to_red
'Mainstreet becomes green
Street = Mainstreet
Gosub Turn_to_green
Wait_for_car:
Wait 5
Turn_to_Green:
Gosub Change_Port_Pin
RB_SettableColor Yellow,Yellow,Light 'load and set color from table
RB_Send 'refresh stripe
Wait 1
RB_clearcolors 'clear colors in memory
RB_SettableColor green,green,Light 'load and set color from table
Wait 2
Turn_to_red:
Wait 3
RB_SettableColor red,red,Light 'load and set color from table
Wait 2
Inital_State:
'select Mainstreet, green
Street = Mainstreet
RB_clearcolors
RB_Send
'select Eaststreet, red
Street = Eaststreet
RB_clearcolors
RB_SettableColor Red,Red,Light
RB_Send
Change_PORT_PIN:
PortPin = Lookup(Street,PortPin_Tbl) 'get PortPin comination
RB_ChangePin High(PortPin),PortPin 'use PortPin
PortPin_Tbl:
Data MainStreet_0%
Data EastStreet_1%
Light:
Data 150,0,0 'Red
Data 100,50,0 'Yello
Data 0,150,0 'Green
