Ands specified color info to the specified LED in memory
RB_ANDCOLOR Led , Color
Color |
Color is a byte array or variable that contains color information. |
Led |
The index of the LED number. First LED is 0. |
The operation is performed on the memory. An AND operation can clear part of a color. You need to use RB_SEND so that the LED reflects the new color information.
CONFIG RAINBOW , RB_ADDCOLOR, RB_ORCOLOR, RB_SUBCOLOR, RB_CLEARSTRIPE , RB_CLEARCOLORS , RB_FILL , RB_FILLCOLORS , RB_FILLSTRIPE , RB_SELECTCHANNEL, RB_SEND, RB_SETCOLOR , RB_SWAPCOLOR , RB_ROTATELEFT, RB_ROTATERIGHT, RB_SHIFTLEFT, RB_SHIFTRIGHT , RB_CHANGEPIN , RB_SETTABLECOLOR , RB_GETCOLOR , RB_LOOKUPCOLOR , RB_COPY , RB_COLOR
' rainbow_ws2812_Demo_Softblink.bas
'This demo show RB_OrColor and RB_AndColor which can be used
'for a flashing LED with a fade effect.
$Regfile = "m88pdef.dat"
$Crystal=8000000
$hwstack=32
$swstack=16
$framesize=32
Config RAINBOW=1, RB0_LEN=8, RB0_PORT=PORTB,rb0_pin=0
' ^ connected to pin 0
' ^------------ connected to portB
' ^-------------------------- 8 leds on stripe
' ^------------------------------------- 1 channel
Const Numled=8
Dim MASK as Dword
Dim Fade as Byte
'----[MAIN]---------------------------------------------------------------------
RB_SelectChannel 0 ' select first channel
For Fade = 0 to 7
Waitms 20
Shift MASK , left
Incr MASK
RB_ORColor 0 , MASK
RB_Send
For Fade = 0 to 7
Waitms 20
Shift MASK , right
RB_ANDColor 0 , MASK
RB_Send
