FM24C64_256-XMEGA is the XMEGA version of the FM24C64_256 library.
This library is a library that uses a RAMTRON I2C serial EEPROM.
Ramtron memory chips are as quick as RAM and can be overwritten almost unlimited times.
An external EEPROM is a safe alternative to the internal EEPROM.
By using : $lib "FM24C64_256-XMEGA.lib"
The EEPROM read and write routines from the library will be used instead of the internal EEPROM.
Thus you can still use : Dim BE as ERAM Byte
And you can use READEEPROM and WRITEEEPROM, but instead of using the internal EEPROM, the external I2C EEPROM is used.
Since Xmega has up to 4 different TWI channels, you need to define which channel is used.
You need to do so by defining a constant in your code named cFRAM_CHANNEL and give it a value of 1 for TWIC, 2 for TWID, 4 for TWIE or 8 for TWIF.
This library is only included in the full version. It is not included with the DEMO.
In version 2086 you can also read write strings.
The fm24c64_256-XMEGA library is a library that uses a RAMTRON I2C serial EEPROM.
By using : $lib "fm24c64_256-xmega.lib"
The lib is for the FM24C515. It uses I2C / TWI.
You must define a constant in your code with a constant that defines the twi interface :
CONST cfram_channel = 1 'twic
CONST cfram_channel = 2 'twid
CONST cfram_channel = 4 'twie
CONST cfram_channel = 8 'twif
This library is especial for XMEGA and serves as a sample. reading/writing strings is NOT supported but can be added by the user
'name : 24C512-xmega-simple-RW test-TWIE.bas
'copyright : (c) 1995-2025, MCS Electronics
'purpose : Testing Read/Write operation with external EEPROM on TWIE
'micro : xmega128A1
'suited for demo : no
'commercial addon needed : no
$regfile = "xM128a1def.dat"
$crystal = 32000000 ' 32MHz
$hwstack = 128
$swstack = 128
$framesize = 128
Config BASE = 0 ' arrays start at 0
'configure the systemclock
'for debug we send some data to the UART
Config Twie = 100000 ' CONFIG TWI will ENABLE the TWI master interface
const cfram_channel = 4 ' this constant is required by the fm24c64_256-xmega lib
' set it to 1 for TWIC , 2 for TWID , 4 for TWIE and 8 for TWIF
Open "twie" For Binary As #4 ' when not using default twic, you must use a channel
const _twi_stop_1 = 1 ' just test i2cstop option, see help
Dim Twi_start As Byte ' always required for xmega i2c
I2Cinit #4
$eepromsize = &H400 ' set it to the size of your EEPROM
$lib "fm24c64_256-xmega.lib" ' include lib
dim ee(100) as eram byte ' dim an EEPROM array
Dim B , adres As byte
print "Writing EEEPROM"
for adres = 0 to 10
print adres ; ",";
ee(adres) = adres
waitms 20 ' ONLY FOR NORMAL EEPROM , REMOVE FOR RAMTRON
next
print
print "read EEEPROM"
for adres = 0 to 10
b = ee(adres)
print adres;"-";b
next
end
