CONFIG VREF
Top  Previous  Next
This configuration statement will configure the XTINY voltage reference.
CONFIG VREF=Dummy, ADCx=ref1,DACx|AC0=ref2, force_adcX=opt1,force_dacX|force_acX=opt2
dummy
There is no actual global setting for VREF so the only option is dummy
ADCx
This will set the voltage reference for the ADC0/ADC1 to the specified value of ref1. The X represents the number 0 or 1 which represents ADC0 and ADC1.
The voltage reference for the ADC ref1 can be :
- 0.55V
- 1.1V
- 4.3V
- 1.5V
The default is 0.55V
The voltage reference can not exceed the supply voltage. So 4.3 is only possible when VCC is 5V
force_adcX
This option allows to force the reference to be running even if it is not requested.
A value of ENABLED will force the reference to be on.
A value of DISABLED which is the default will set the reference in automatic mode. In this mode the reference is turned on when requested. This will save power.
DACx
AC0
This will set the voltage reference for the DACx and/or ACx to the specified value of ref2. Note that ADCx and DACx/ACx reference can be set in depended of each other.
The X indicates a number 0,1 or 2 which represents DAC0, DAC1 and DAC2.
The voltage reference for the DAC which can be :
- 0.55V
- 1.1V
- 4.3V
- 1.5V
force_dacX
force_acX
As for the other options, the X represents the peripheral DAC/AC.
Note that not all processors have an ADC and/or DAC. It depends on the processor.
Some processors have multiple ADC and/or DAC.
The DAC and AC are grouped together. The IDE will show the proper options depending on the chosen processor when using CTRL+SPACE
CONFIG ADC0
