Language Fundamentals
Top  Previous  Next
Characters from the BASCOM character set are put together to form labels, keywords, variables and operators.
These in turn are combined to form the statements that make up a program.
This chapter describes the character set and the format of BASCOM program lines. In particular, it discusses:
The specific characters in the character set and the special meanings of some characters.
The format of a line in a BASCOM program.
Line labels.
Program line length.
Character Set
The BASCOM numeric characters are the digits 0-9.
The letters A-H can be used as parts of hexadecimal numbers.
The following characters have special meanings in BASCOM statements and expressions:
Character
Name
ENTER
Terminates input of a line
Blank ( or space)
Single quotation mark (apostrophe)
Asterisks (multiplication symbol)
Plus sign
Comma
Minus sign
Period (decimal point)
Slash (division symbol) will be handled as \
Colon
Double quotation mark
Semicolon
Less than
Equal sign (assignment symbol or relational operator)
Greater than
Backslash (integer/word division symbol)
Exponent
The BASCOM program line
BASCOM program lines have the following syntax:
[[line-identifier]] [[statement]] [[:statement]] ... [[comment]]
Using Line Identifiers
BASCOM support one type of line-identifier; alphanumeric line labels:
An alphabetic line label may be any combination of from 1 to 32 letters and digits, starting with a letter and ending with a colon.
BASCOM keywords are not permitted.
The following are valid alphanumeric line labels:
Alpha:
ScreenSUB:
Test3A:
Case is not significant. The following line labels are equivalent:
alpha:
Alpha:
ALPHA:
Line labels may begin in any column, as long as they are the first characters other than blanks on the line.
Blanks are not allowed between an alphabetic label and the colon following it.
A line can have only one label. When there is a label on the line, no other identifiers may be used on the same line. So the label is the sole identifier on a line.
BASCOM Statements
REM or (starts a comment)
DIM
BASCOM LineLength
Data Types
Elementary Data Types
Bit (1/8 byte). A bit can hold only the value 0 or 1. A group of 8 bits is called a byte.
Byte (1 byte).  Bytes are stores as unsigned 8-bit binary numbers ranging in value from 0 to 255.
Integer (two bytes). Integers are stored as signed sixteen-bit binary numbers ranging in value from -32,768 to +32,767.
Word (two bytes). Words are stored as unsigned sixteen-bit binary numbers ranging in value from 0 to 65535.
Long (four bytes). Longs are stored as signed 32-bit binary numbers ranging in value from -2147483648 to 2147483647.
Single. Singles are stored as signed 32 bit binary numbers. Ranging in value from 1.5 x 10^–45 to 3.4 x 10^38
Double. Doubles are stored as signed 64 bit binary numbers. Ranging in value from 5.0 x 10^–324 to 1.7 x 10^308
String (up to 254 bytes). Strings are stored as bytes and are terminated with a 0-byte. A string dimensioned with a length of 10 bytes will occupy 11 bytes.
Variables
A constant value:
A = 5
C = 1.1
The value of another numeric variable:
abc = def
k = g
The value obtained by combining other variables, constants, and operators: Temp = a + 5
Temp = C + 5
The value obtained by calling a function:
Temp = Asc(S)
Variable Names
AND = 8
ToAND = 8
(see BASCOM Reserved Words , for a complete list of reserved words).
Before assigning a variable, you must tell the compiler about it with the DIM statement.
You can also use DEFINT, DEFBIT, DEFBYTE ,DEFWORD ,DEFLNG or DEFSNG.
Expressions and Operators
Arithmetic operators, used to perform calculations.
Relational operators, used to compare numeric or string values.
Logical operators, used to test conditions or manipulate individual bits.
Functional operators, used to supplement simple operators.
1. Arithmetic
2. Relational
3. Logical
4. Functional
Arithmetic
Integer
Example: Z = X \ Y
Modulo Arithmetic
Modulo arithmetic provides the remainder, rather than the quotient, of   an integer division.
Example: X = 10 \ 4 : remainder = 10 MOD 4
Overflow and division by zero
Relational Operators
Operator
Relation Tested
Expression
Equality
X = Y
Inequality
X <> Y
Less than
X < Y
Greater than
X > Y
Less than or equal to
X <= Y
Greater than or equal to
X >= Y
Logical Operators
There four operators in BASCOM are :
Operator
Meaning
NOT
Logical complement
AND
Conjunction
OR
Disjunction
XOR
Exclusive or
A = 63 And 19
PRINT A
A = 10 Or 9
PRINT A
Output
19
11
s exponent mantissa
Dim I as Integer, S as Single
S = 100.1 'assign the single
I = S  'will convert the single to an integer
500 + 30 + 2 + 2/10 + 5/100
_________
= 532.25
4 + 0 + 1 + 0 + 1/4
_________
= 5.25 Decimal
1 Decimal = 1 Binary
2 Decimal = 10 Binary
Floating-Point Complications
SUM = 0
FOR I% = 1 TO 10000
SUM = SUM + 0.0001
NEXT I%
item1# = 69.82#
item2# = 69.20# + 0.62#
IEEE Details
Single-Precision Examples
1. Round-off error
.1235
-.1234
_____
.0001
3. Overflow and underflow
4. Quantizing error
Rounding
Double
Arrays
The maximum number of elements is 65535.
The first element of an array is always one. This means that elements are 1-based.
Example:
Dim A(10) As Byte
'create an integer
Dim C As Integer
'now fill the array
For C = 1 To 10
'assign array element
A(c)= C
' print it
Print A(c)
C = 0
A(c + 1)= 100
Print A(c + 1)
Strings
DIM S as STRING * 5
To assign the string:
s = "abcd"
s= "AB{027}cd"
The number of digits must be 3. s = "{27} will assign "{27}" to the string instead of escape character 27!
Casting
Byte = LONG
Dim b as Byte
b = 123 ' ok this is normal
b = "A" ' b = 65
IF b = "A" then ' when b = 65
END IF
SINGLE CONVERSION
integer = single
single = long
