CONFIG COM1
Top  Previous  Next
Configures the UART of AVR chips that have an extended UART like the M8.
CONFIG COM1 = baud , synchrone=0|1,parity=none|disabled|even|odd,stopbits=1|2,databits=4|6|7|8|9,clockpol=0|1
baud
Baud rate to use. Use 'dummy' to leave the baud rate at the $baud value.
synchrone
0 for asynchrone operation (default) and 1 for synchrone operation.
Parity
None, disabled, even or odd
Stopbits
The number of stop bits : 1 or 2
Databits
The number of data bits : 4,5,7,8 or 9.
Clockpol
Clock polarity. 0 or 1.
noticeNote that not all AVR chips have the extended UART. Most AVR chips have a UART with fixed communication parameters. These are : No parity, 1 stop bit, 8 data bits.
Normally you set the BAUD rate with $BAUD or at run time with BAUD. You may also set the baud rate when you open the COM channel. It is intended for the Mega2560 that has 4 UARTS and it is simpler to specify the baud rate when you open the channel. It may also be used with the first and second UART but it will generate additional code since using the first UART will always result in generating BAUD rate init code.
See Also
CONFIG COM2 , CONFIG COMx
'name                     :
'copyright                : (c) 1995-2005, MCS Electronics
'purpose                  : test for M128 support in M128 mode
'micro                    : Mega128
$regfile = "m128def.dat"                                   ' specify the used micro
$crystal = 4000000                                         ' used crystal frequency
$baud = 19200                                               ' use baud rate
$baud1 = 19200
'By default the M128 has the M103 compatibility fuse set. Set the fuse to M128
'It also runs on a 1 MHz internal oscillator by default
'Set the internal osc to 4 MHz for this example DCBA=1100
'use the m128def.dat file when you wanto to use the M128 in M128 mode
'The M128 mode will use memory from $60-$9F for the extended registers
'Since some ports are located in extended registers it means that some statements
'will not work on these ports. Especially statements that will set or reset a bit
'in a register. You can set any bit yourself with the PORTF.1=1 statement for example
'But the I2C routines use ASM instructions to set the bit of a port. These ASM instructions may
'only be used on port registers. PORTF and PORTG will not work with I2C.
'The M128 has an extended UART.
'when CONFIG COMx is not used, the default N,8,1 will be used
Config Com2 = Dummy , Synchrone = 0 , Parity = None , Stopbits = 1 , Databits = 8 , Clockpol = 0
'try the second hardware UART
Open "com2:" For Binary As #1
'try to access an extended register
Config Portf = Output
'Config Portf = Input
Print "Hello"
Dim B As Byte
Input "test serial port 0" , B
Print B
Print #1 , "test serial port 2"
Close #1
