Tools Plugin Manager
Top  Previous  Next
The Plug in Manager allows you to specify which Plug-in's needs to be loaded the next time you start BASCOM.
pluginmng
Just select the plug in's you want to load/use by setting the check box.
The plug in's menu's will be loaded under the Tools Menu.
To add a button to the toolbar,  right click the mouse on the menu bar, and choose customize.
When you want to write your own plug in's, contact support@mcselec.com
