With this option you can modify the printer settings.
OPTION |
DESCRIPTION |
Font |
Printer font to use when printing |
Setup |
Click to change the printer setup |
Color |
Will print in color. Use this only for color printers. |
Wrap lines |
Wrap long lines. When not enabled, long lines will be partial shown. |
Print header |
Print a header with the filename. |
Line numbers |
Will be the line number before each line. |
Syntax |
Enable this to use the same syntax highlighting as the editor |
Left margin |
The left margin of the paper. |
Right margin |
The right margin of the paper. |
Top margin |
The top margin of the paper. |
Bottom margin |
The bottom margin of the paper. |
