Options Compiler I2C, SPI, 1WIRE
Top  Previous  Next
options_compiler_i2c
Item
Description
SCL port
Select the port pin that serves as the SCL-line for the I2C related statements.
SDA port
Select the port pin that serves as the SDA-line for the I2C related statements.
1WIRE
Select the port pin that serves as the 1WIRE-line for the 1Wire related statements.
Clock
Select the port pin that serves as the clock-line for the SPI related statements.
MOSI
Select the port pin that serves as the MOSI-line for the SPI related statements.
MISO
Select the port pin that serves as the MISO-line for the SPI related statements.
SS
Select the port pin that serves as the SS-line for the SPI related statements.
Use hardware SPI
Select to use built-in hardware for SPI, otherwise software emulation of SPI will be used. The 2313 does not have internal HW SPI so it can only be used with software SPI mode.
When you do use hardware SPI, the above settings are not used anymore since the SPI pins are dedicated pins and can not be chosen by the user.
It is advised to use the various CONFIG commands in your source code. It make more clear in the source code which pins are used.
