Branch to one of several specified labels, depending on the value of a variable.
ON var GOTO|GOSUB label1 [, label2 ] [,CHECK]
Var |
The numeric variable to test. This can also be a SFR such as PORTB. |
label1, label2 |
The labels to jump to depending on the value of var. |
CHECK |
An optional check for the number of provided labels. When used, the maximum number of labels is 255. The check will insert code to jump over the address jump block. This will limit the number of entries. |
Note that the index value is zero based. So when var is 0, the first specified label is jumped/branched.
It is important that each possible value has an associated label.
You must specify if you jump to the label or that you call the the label.
Use GOTO to jump to the label. Program flow will continue at that label.
Use GOSUB to call the label. The label must have a matching RETURN. Optional you can call a sub routine but it may not have parameters.
When there are not enough labels, the stack will get corrupted. For example :
ON value GOTO label1, label2
When the variable value has a value of two (2), there is no associated label.
You can use the optional CHECK so the compiler will check the value against the number of provided labels. When there are not enough labels for the value, there will be no GOTO or GOSUB and the next line will be executed.
See Also
ON INTERRUPT , GOTO , GOSUB
The following code will be generated for a non-MEGA micro with ON value GOTO.
Ldi R26,$60 ; load address of variable
Ldi R27,$00 ; load constant in register
Ld R24,X
Clr R25
Ldi R30, Low(ON_1_ * 1) ; load Z with address of the label
Ldi R31, High(ON_1_ * 1)
Add zl,r24 ; add value to Z
Adc zh,r25
Ijmp ; jump to address stored in Z
ON_1_:
Rjmp lbl1 ; jump table
Rjmp lbl2
Rjmp lbl3
The following code will be generated for a non-MEGA micro with ON value GOSUB.
;##### On X Gosub L1 , L2
Ldi R30,Low(ON_1_EXIT * 1)
Ldi R31,High(ON_1_EXIT * 1)
Push R30 ;push return address
Push R31
Ldi R30,Low(ON_1_ * 1) ;load table address
Ldi R31,High(ON_1_ * 1)
Ldi R26,$60
Ld R24,X
Clr R25
Add zl,r24 ; add to address of jump table
Adc zh,r25
Ijmp ; jump !!!
ON_1_:
Rjmp L1
Rjmp L2
ON_1_EXIT:
As you can see a jump is used to call the routine. Therefore the return address is first saved on the stack.
Example 1
'name : ongosub.bas
'copyright : (c) 1995-2025, MCS Electronics
'purpose : demo : ON .. GOSUB/GOTO
'micro : Mega48
'suited for demo : yes
'commercial addon needed : no
Dim A As Byte
Input "Enter value 0-2 " , A 'ask for input
Rem Note That The Starting Value Begins With 0
On A Gosub L0 , L1 , L2
Print "Returned"
If Portb < 2 Then 'you can also use the portvalue
On Portb Goto G0 , G1
End_prog:
L0:
Print "0 entered"
L1:
Print "1 entered"
L2:
Print "2 entered"
G0:
Print "P1 = 0"
Goto End_prog
G1:
Print "P1 = 1"
Goto End_prog
Example 2
This sample use call/sub instead of labels
'name : ongosub.bas
'micro : Mega48
Declare Sub L0()
Declare Sub L1()
Declare Sub L2()
Dim A As Byte
Print "Returned"
End_prog:
Sub L0()
Print "0 entered"
End Sub
Sub L1()
Print "1 entered"
End Sub
Sub L2()
Print "2 entered"
End Sub
G0:
Print "P1 = 0"
Goto End_prog
G1:
Print "P1 = 1"
Goto End_prog
