LCD_DOGS104a_I2C
Top  Previous  Next
This is a user contributed lbx for the EADOGS104 with the SSD1803A.
The SAMPLES\LCDGRAPH folder contains the sample :
'                        DOGS-104.bas
'       Demonstration for DOGS 104-A display
'                  (c) R. Müller-Westermann
'                       HB9EFQ@yahoo.com
$regfile = "m168def.dat"
$crystal = 1000000
'$sim
$hwstack = 32
$swstack = 32
$framesize = 64
$lib "Lcd_dogs104a_i2c.lbx"
'LCD  -----------------------------------------------------------------
'chipset:DOGS104V3
'DOGS104 Display can use either &H78 if pin SA0 of module is set to GND
'or &H7A if SA0 of module is set to VDD for I²C communication.
'Pullup resistors on SDA and SCL lines of less or equal to 3.9kOhm @3.3V
'are recommended.
Const Dogs104_adr_w = &H78                                 'I²C write address
Const Dogs104_adr_r = &H79                                 'I²C read address
'LCD has 2 view options. If LCD_view is set to 0 characters are being
'displayed in bottom view (6 o'clock). If set to 1 characters are being
'displayed in top view (12 0'clock)
Const Lcd_view = 0                                         'bottom view
'Const Lcd_view = 1                                         'top View
'configuration is needed for defining start address of LCD RAM
Config Lcd = 20x2
'LCD comes with 3 different character sets. These can be accessed by setting
'LCD_ROM
Const Lcd_rom = 1                                         'ROM A
'Const Lcd_rom = 2                                          'ROM B
'Const Lcd_rom = 3                                          'ROM C
'there are 2 custom procedures witch provide number of lines switching at
'runtime. You can either choose 2 line mode with double hight fonts or regular
'4 line mode. This is the standard mode used by Initlcd.
$external 2line_mode
$external 4line_mode
Declare Sub 2line_mode
Declare Sub 4line_mode
'TWI-------------------------------------------------------------------
Config Scl = Portc.5
Config Sda = Portc.4
I2cinit
Initlcd
Waitms 100
'As with any other LCD module, you can define up to 8 additional characters
'by using the regular Bascom command
  Deflcdchar 1 , 32 , 32 , 4 , 10 , 17 , 10 , 4 , 32     ' circle
Cls
Waitms 100
Cursor Off
Locate 1 , 1 : Lcd Chr(1)
Wait 2
'standard initialization of LCD is set to 4 line mode
Cls
Locate 1 , 1 : Lcd "line 1"
Locate 2 , 1 : Lcd "line 2"
Locate 3 , 1 : Lcd "line 3"
Locate 4 , 1 : Lcd "line 4"
Wait 2
Cls
'if needed LCD can be switched to 2 line mode
2line_mode
Locate 1 , 3 : Lcd "line 1"
Locate 2 , 3 : Lcd "line 2"
Wait 2
' ... and back to 4 line mode
4line_mode
Cls
Locate 1 , 3 : Lcd "line 1 "
Locate 3 , 3 : Lcd "line 3"
Locate 4 , 3 : Lcd "line 4"
Wait 2
'if desired you can put the LCD module in power down mode. This saves some
'400µA.
'Any other command applicable for DOGS104A using SSD1803A controller can be
'issued by using regular Rcall _Lcd_control command with preloaded
'R24 register.
Display Off
Waitms 100
'power down ----------------
R24 = &B00111010                                           '8 bit data RE1, REV0
Lcdcmd R24
R24 = &B00000011                                           'power down
Lcdcmd R24
R24 = &B00111000                                           '8 bit data RE0, IS0
Lcdcmd R24
Wait 2
'... and power up again. LCD RAM remains unchanged.
'power up -----------------
Lcdcmd R24
R24 = &B00000010                                           'power up
Lcdcmd R24
Lcdcmd R24
Waitms 100
Display On
Locate 4 , 1 : Lcd "powered up"
