I2C_USI_SLAVE
Top  Previous  Next
The I2C_USI_SLAVE library is a library that ships with the I2C slave add on package.
The purpose of the lib is to offer I2C/TWI slave support for processors that have an USI interface.
USI master support is bundled with the commercial version of Bascom. This library is named i2_USI.
The USI has two interrupts. One to detect the START condition and one to detect a counter overflow.
Unfortunately Atmel did not define an interrupt for STOP condition. This means that it is not possible to detect a STOP condition with an interrupt.
You can read the STOP condition bit from the USISR register but no interrupt will fire as for the START condition.
So in practice, the Twi_stop_received label will be called just before the I2CSTART is called or when data is clocked by the master.
The following example demonstrates how to receive multiple bytes. It emulates an I2c, EEPROM memory chip.
'                            (c) 1995-2025 MCS Electronics
'       This demo demonstrates the USI I2C slave and emulates an EEPROM chip
'          This is part of the I2C Slave library which is a commercial addon library
'          Not all AVR chips have an USI !!!!
' This is a simple sample. the master sends the address of the slave, the WORD address
'  of the memory location, and a byte to store or read
' The matching master code to write
'   i2cstart : i2cwbyte &H40 : i2cwbyte low(address) : i2cwbyte high(address) : i2cwbyte value : i2cstop
' The mathing master code to read
'   i2cstart : i2cwbyte &H40 : i2cwbyte low(address) : i2cwbyte high(address) : i2crepstart : i2cwbyte &H41 : i2cRbyte value, nack : i2cstop
'See also the eeprom_master.bas
$regfile = "attiny2313.dat"
'$regfile = "attiny85.dat"
$crystal = 8000000
$hwstack = 44
$swstack = 16
$framesize = 28
config CLOCKDIV=1
'I2C pins on tiny2313 connected like :
'PB5 SDA
'PB7 SCL
'I2C pins on tiny85 connected like :
'PB0 SDA
'PB2 SCL
config BASE=0                                               'arrays start at address 0
Const Cprint = 0                                           'make 0 for chips that have NO UART, make 1 when the micro has a UART and you want to show data on the terminal
#if cPrint
  Config Com1 = 19200 , Synchrone = 0 , Parity = None , Stopbits = 1 , Databits = 8 , Clockpol = 0
  print "USI DEMO"
#endif
config usi = twislave , address = &H40                     'bascom uses 8 bit i2c address (7 bit shifted to the left with one bit)
dim epr(128) as Eram byte                 'for easy access to the memory
dim wAdres as Word, bValue as Byte
dim bAdresL as Byte at Wadres overlay     'overlay with wAdres LSB
dim bAdresH as Byte at Wadres+1 overlay   'overlay with wAdres MSB
'do not forget to enable global interrupts since USI is used in interrupt mode
enable interrupts                                           'it is important you enable interrupts
do
  ! nop                                                   ; nothing to do here
loop
'The following labels are called from the library. You need to insert code in these subroutines
'Notice that the PRINT commands are remarked.
'You can unmark them and see what happens, but it will increase code size
'The idea is that you write your code in the called labels. And this code must execute in as little time
'as possible. So when you slave must read the A/D converter, you can best do it in the main program
'then the data is available when the master requires it, and you do not need to do the conversion which cost time.
'A master can send or receive bytes.
'A master protocol can also send some bytes, then receive some bytes
'The master and slave address must match.
'the following labels are called from the library  when master send stop or start
Twi_start_received:
  #if cprint
    Print "Master sent start or repeated start"
  #endif
Twi_stop_received:
  #if cprint
    Print "Master sent stop"
  #endif
'master sent our slave address and will now send data
Twi_addressed_goread:
  #if cprint
    Print "We were addressed and master will send data"
  #endif
Twi_addressed_gowrite:
  #if cprint
    Print "We were addressed and master will read data"
  #endif
'this label is called when the master sends data and the slave has received the byte
'the variable TWI holds the received value
Twi_gotdata:
  #if cprint
    Print "received : " ; Twi ; " byte no : " ; Twi_btw ; "-"; usidr
  #endif
  Select Case Twi_btw
    Case 1 : bAdresL=TWI 'first byte is LSB
    Case 2 : bAdresH=TWI 'second byte is MSB
    case 3 :
        #if cprint
          print "address:" ; wAdres
        #endif
        epr(wAdres)=twi 'write to eeprom in case we receive a third byte which should only happen when we write to the slave
  End Select
'if you want to auto inc wAdres, use this code instead:
'   Select Case Twi_btw
'      Case 1 : bAdresL=TWI 'first byte is LSB
'      Case 2 : bAdresH=TWI 'second byte is MSB
'      case else : epr(wAdres)=twi 'write to eeprom in case we receive a third byte which should only happen when we write to the slave
'                 incr wAdres
'   End Select
'this label is called when the master receives data and needs a byte
'the variable twi_btr is a byte variable that holds the index of the needed byte
'so when sending multiple bytes from an array, twi_btr can be used for the index
Twi_master_needs_byte:
  #if cprint
    Print "Master needs byte : " ; Twi_btr
  #endif
  twi=epr(wAdres) 'return the data from EEPROM
  'when you want to support auto adres increase add this :
  'incr wAdres
The following master sample can be used with the slave sample.
Master sample
'                        eeprom_master.bas
'                    demo for USI eeprom slave
$Regfile= "m88pdef.dat"
$crystal=8000000
$HWstack=40
$SWstack=50
$FrameSize=40
$baud=19200
$lib "i2c_twi.lbx"             ' we do not use software emulated I2C but the TWI
config CLOCKDIV=1             ' no need to change fuse byte, we set the divider to 1
Config Sda = Portc.4                                       ' I2C Bus konfigurieren
Config Scl = Portc.5
Dim Address As Word
Dim Value As Byte
'osccal=46             'REMARK THIS LINE, THIS WAS REQUIRED for the test chip
Print "Start"
I2cinit                         ' init i2c
For Address = 0 To 10                                   ' just test a bit
  value=address+10
  print "write "; address ; ":";value
  I2cstart : I2cwbyte &H40                             'slave address
  I2cwbyte Low(address)                               'LSB first
  I2cwbyte High(address)                               'MSB
  I2cwbyte Value                                       'write value
  I2cstop
  Waitms 500
next
print "Read"
  I2cstart : I2cwbyte &H40                             'send slave WRITE address
  I2cwbyte Low(address) : I2cwbyte High(address) :   'send eeprom address
  I2crepstart                                         'repeated start
  I2cwbyte &H41                                       'write slave READ address
  I2crbyte Value , Nack                               'read eeprom value
  I2cstop
  print address;":";value
Next Address                                             ' increment address byte
end
'EXPECTED OUTPUT
Start
write 0:10
write 1:11
write 2:12
write 3:13
write 4:14
write 5:15
write 6:16
write 7:17
write 8:18
write 9:19
write 10:20
Read
0:10
1:11
2:12
3:13
4:14
5:15
6:16
7:17
8:18
9:19
10:20
