This library is based on work of Ben Zijstra and Heiko/Hkipnik
The library supports the SSD1306 graphical LCD in I2C mode.
Since the display can not read data back, the library supports only the graphical write statements. Commands like LINE, PSET and CIRCLE which need to alter a single pixel are not supported.
XMEGA
For use with XMEGA you need to define 2 constants in your code.
const TWI_ADR = interface
const TWI_CH = num
The interface must point to the TWI control register, this could be : TWIC_CTRL but aldo TWID_CTRL, TWIE_CTRL and TWIF_CTRL
The TWI_CH constant with the value num, must be 1 for TWIC, 2 for TWID, 4 for TWIE and 8 for TWIF
The reference to : $lib "i2c_twi.lbx" must be removed.
' SSD1306-I2C.BAS
' (c) 1995-2025 MCS Electronics
' Sample to demo the 128x64 I2C OLED display
$regfile = "m88pdef.dat"
$hwstack = 32
$swstack = 32
$framesize = 32
$crystal = 8000000
Config Clockdiv = 1 ' make sure the chip runs at 8 MHz
Config Scl = Portc.5 ' used i2c pins
Config Sda = Portc.4
Config Twi = 400000 ' i2c speed
I2cinit
$lib "i2c_twi.lbx" ' we do not use software emulated I2C but the TWI
$lib "glcdSSD1306-I2C.lib" ' override the default lib with this special one
#if _build < 20784
Dim ___lcdrow As Byte , ___lcdcol As Byte ' dim these for older compiler versions
#endif
Config Graphlcd = Custom , Cols = 128 , Rows = 64 , Lcdname = "SSD1306"
Cls
Setfont Font8x8tt ' select font
Lcdat 1 , 1 , "BASCOM-AVR"
Lcdat 2 , 10 , "1995-2020"
Lcdat 8 , 5 , "MCS Electronics" , 1
Waitms 3000
Showpic 0 , 0 , Plaatje
$include "font8x8TT.font" ' this is a true type font with variable spacing
Plaatje:
$bgf "ks108.bgf" ' include the picture data
