Create settings related to USB.
CONFIG USB = dev, Language= lang, Manufact= "man", Product="prod" , Serial="serial"
Dev  |
The possible options are Device and Host. Host is not supported yet.  |
Lang  |
A language identifier. &H0409 for US/English  |
Man  |
A string constant with the manufacture name.  |
Prod  |
A string constant with the product name.  |
Serial  |
A string constant with the serial number.  |
The above settings determine how your device is displayed by the operating system.
Since these settings end up in flash code space, it is best to chose short names. There is no limit to the length other then the USB specifications impose, but keep it short as possible. Strings in USB are UNI coded. Which mean that a word is used for each character. with normal ASCII coding, only a byte is used for each character.
For a commercial USB device you need to give it a unique VID & PID combination. When you plan to use it at home, this is not needed.
You can buy a Vendor ID (VID) from the USB organization. This cost 2000 $.
As a service MCS offers a PID in the on line shop. This cost little and it gives you a unique Product ID(PID) but with the MCS Electronics VID.
Notice that using CONFIG USB will include a file named USBINC.BAS. This file is not part of the BASCOM setup/distribution. It is available as a commercial add on. The add on package includes 3 samples , the include file, and a special activeX for the HID demo.
None of the samples require a driver. A small UB162 module with normal pins is available from the on line shop too.
The first supported USB devices are USB1287, USB162.
$regfile = "usb162.dat"
$crystal = 8000000
$baud = 19200
Const Mdbg = 1
Config Clockdiv = 1
Const Vendor_id = &H16D0 ' MCS Vendor ID
Const Product_id = &H201D ' MCS product ID, you can buy a VID&PID in the MCS shop
Const Ep_control_length = 32
Const User_conf_size = 41
Const Size_of_report = 53
Const Device_class = 0
Const Device_sub_class = 0
Const Device_protocol = 0
Const Release_number = &H1000
Const Length_of_report_in = 8
Const Length_of_report_out = 8
Const Interface_nb = 0
Const Alternate = 0
Const Nb_endpoint = 2
Const Interface_class = 3 ' HID
Const Interface_sub_class = 0
Const Interface_protocol = 0
Const Interface_index = 0
Print "USB GENERIC test"
Declare Sub Usb_user_endpoint_init
Declare Sub Hid_test_hit()
Declare Sub Hid_task()
Declare Sub Hid_task_init()
Const Usb_config_attributes_reserved = &H80
Const Usb_config_buspowered = Usb_config_attributes_reserved
Const Usb_config_selfpowered = Usb_config_attributes_reserved Or &H40
Const Usb_config_remotewakeup = Usb_config_attributes_reserved Or &H20
Const Nb_interface = 1
Const Conf_nb = 1
Const Conf_index = 0
Const Conf_attributes = Usb_config_buspowered
Const Max_power = 50 ' 100 mA
Const Interface_nb_mouse = 0
Const Alternate_mouse = 0
Const Nb_endpoint_mouse = 1
Const Interface_class_mouse = 3 ' HID Class
Const Interface_sub_class_mouse = 1 ' Sub Class is Mouse
Const Interface_protocol_mouse = 2 ' Mouse
Const Interface_index_mouse = 0
Const Nb_endpoints = 2 ' number of endpoints in the application including control endpoint
Const Ep_kbd_in = 1 ' Number of the mouse interrupt IN endpoint
Const Ep_hid_in = 1
Const Ep_hid_out = 2
Const Endpoint_nb_1 = Ep_hid_in Or &H80
Const Ep_attributes_1 = 3 ' BULK = 0x02, INTERUPT = 0x03
Const Ep_in_length_1 = 8
Const Ep_size_1 = Ep_in_length_1
Const Ep_interval_1 = 20 ' Interrupt polling interval from host
Const Endpoint_nb_2 = Ep_hid_out
Const Ep_attributes_2 = 3 ' BULK = 0x02, INTERUPT = 0x03
Const Ep_out_length = 8
Const Ep_size_2 = Ep_out_length
Const Ep_interval_2 = 20 ' interrupt polling from host
Config Usb = Device , Language = &H0409 , Manufact = "MCS" , Product = "MCSHID162" , Serial = "MC0001"
'Dim some user vars
Dim Usb_kbd_state As Byte , Usb_key As Byte , Usb_data_to_send As Byte
Dim Dummy As Byte , Dummy1 As Byte , Dummy2 As Byte
Print "task init"
Usb_task_init
Hid_task_init
Usb_task
Hid_task
'you can call your sub program here
'nothing needed to init
Sub Hid_task_init()
'nothing
end sub
'HID task must be checked regular
Sub Hid_task()
If Usb_connected = 1 Then ' Check USB HID is enumerated
Usb_select_endpoint Ep_hid_out ' Get Data Repport From Host
If Ueintx.rxouti = 1 Then ' Is_usb_receive_out())
Dummy1 = Uedatx : Print "Got : " ; Dummy1
Dummy2 = Uedatx : Print "Got : " ; Dummy2
Dummy = Uedatx : Print "Got : " ; Dummy
Usb_ack_receive_out
If Dummy1 = &H55 And Dummy2 = &HAA Then ' Check if we received DFU mode command from host
Usb_detach ' Detach Actual Generic Hid Application
Waitms 500
Goto &H1800 'goto bootloader
'here you could call the bootloader then
Usb_select_endpoint Ep_hid_in ' Ready to send these information to the host application
If Ueintx.txini = 1 Then ' Is_usb_in_ready())
Uedatx = 1
Uedatx = 2
Uedatx = 3
Uedatx = 4
Uedatx = 5
Uedatx = 6
Uedatx = 7
Uedatx = 8
Usb_ack_fifocon ' Send data over the USB
End Sub
Function Usb_user_read_request(type As Byte , Request As Byte) As Byte
#if Mdbg
Print "USB_USER_READ_REQ"
#endif
Usb_string_type = Uedatx 'Usb_read_byte();
Usb_descriptor_type = Uedatx 'Usb_read_byte();
Usb_user_read_request = 0
Select Case Request
Case Get_descriptor:
Select Case Usb_descriptor_type
Case Report : Call Hid_get_report()
Usb_user_read_request = 1
Case Hid : Call Hid_get_hid_descriptor()
Case Else
End Select
Case Set_configuration:
Case Set_report : Call Hid_set_report()
Case Else
End Select
Case Get_interface:
'// usb_hid_set_idle();
Call Usb_hid_get_interface()
Case Else
End Select
End Function
'usb_init_device.
'This function initializes the USB device controller and
'configures the Default Control Endpoint.
Sub Usb_init_device()
#if Usbfunc
Usb_select_device
#endif
#if Usbfunc
If Usbsta.id = 1 Then 'is it an USB device?
#endif
Uenum = Ep_control ' select USB endpoint
If Ueconx.epen = 0 Then ' usb endpoint not enabled yet
Call Usb_configure_endpoint(ep_control , Type_control , Direction_out , Size_32 , One_bank , Nyet_disabled)
#if Usbfunc
#endif
End Sub
Sub Usb_user_endpoint_init(byval Nm As Byte)
Call Usb_configure_endpoint(ep_hid_in , Type_interrupt , Direction_in , Size_8 , One_bank , Nyet_enabled)
Call Usb_configure_endpoint(ep_hid_out , Type_interrupt , Direction_out , Size_8 , One_bank , Nyet_enabled)
End Sub
Usb_dev_desc:
Data 18 , Device_descriptor 'size and device_descriptor
Data 0 , 2 'Usb_write_word_enum_struc(USB_SPECIFICATION)
Data Device_class , Device_sub_class ' DEVICE_CLASS and DEVICE_SUB_CLASS
Data Device_protocol , Ep_control_length ' device protol and ep_control_length
Data Vendor_id% ' Usb_write_word_enum_struc(VENDOR_ID)
Data Product_id% ' Usb_write_word_enum_struc(PRODUCT_ID)
Data Release_number% ' Usb_write_word_enum_struc(RELEASE_NUMBER)
Data Man_index , Prod_index ' MAN_INDEX and PROD_INDEX
Data Sn_index , Nb_configuration ' SN_INDEX and NB_CONFIGURATION
Usb_conf_desc:
Data 9 , Configuration_descriptor ' length , CONFIGURATION descriptor
Data User_conf_size% ' total length of data returned
Data Nb_interface , Conf_nb ' number of interfaces for this conf. , value for SetConfiguration resquest
Data Conf_index , Conf_attributes ' index of string descriptor , Configuration characteristics
Data Max_power ' maximum power consumption
Data 9 , Interface_descriptor 'length , INTERFACE descriptor type
Data Interface_nb , Alternate 'Number of interface , value to select alternate setting
Data Nb_endpoint , Interface_class 'Number of EP except EP 0 ,Class code assigned by the USB
Data Interface_sub_class , Interface_protocol 'Sub-class code assigned by the USB , Protocol code assigned by the USB
Data Interface_index 'Index Of String Descriptor
Data 9 , Hid_descriptor 'length , HID descriptor type
Data Hid_bdc% , 8 ' Binay Coded Decimal Spec. release , Hid_country_code
Data Hid_class_desc_nb , Hid_descriptor_type 'Number of HID class descriptors to follow , Report descriptor type
Data Size_of_report% 'HID KEYBOARD LENGTH
Data 7 , Endpoint_descriptor ' Size Of This Descriptor In Bytes , ENDPOINT descriptor type
Data Endpoint_nb_1 , Ep_attributes_1 ' Address of the endpoint ,Endpoint's attributes
Data Ep_size_1% ' Maximum packet size for this EP , Interval for polling EP in ms
Data Ep_interval_1
Data Endpoint_nb_2 , Ep_attributes_2 ' Address of the endpoint , Endpoint's attributes
Data Ep_size_2% ' Maximum packet size for this EP
Data Ep_interval_2 ' Interval for polling EP in ms
Usb_hid_report:
Data &H06 , &HFF , &HFF ' 04|2 , Usage Page (vendordefined?)
Data &H09 , &H01 ' 08|1 , Usage (vendordefined
Data &HA1 , &H01 ' A0|1 , Collection (Application)
' // IN report
Data &H09 , &H02 ' 08|1 , Usage (vendordefined)
Data &H09 , &H03 ' 08|1 , Usage (vendordefined)
Data &H15 , &H00 ' 14|1 , Logical Minimum(0 for signed byte?)
Data &H26 , &HFF , &H00 ' 24|1 , Logical Maximum(255 for signed byte?)
Data &H75 , &H08 ' 74|1 , Report Size(8) = field size in bits = 1 byte
Data &H95 , Length_of_report_in ' 94|1:ReportCount(size) = repeat count of previous item
Data &H81 , &H02 ' 80|1: IN report (Data,Variable, Absolute)
' // OUT report
Data &H09 , &H04 ' 08|1 , Usage (vendordefined)
Data &H09 , &H05 ' 08|1 , Usage (vendordefined)
Data &H95 , Length_of_report_out ' 94|1:ReportCount(size) = repeat count of previous item
Data &H91 , &H02 ' 90|1: OUT report (Data,Variable, Absolute)
' // Feature report
Data &H09 , &H06 ' 08|1 , Usage (vendordefined)
Data &H09 , &H07 ' 08|1 , Usage (vendordefined)
Data &H15 , &H00 ' 14|1 , LogicalMinimum(0 for signed byte)
Data &H26 , &HFF , &H00 ' 24|1 , Logical Maximum(255 for signed byte)
Data &H75 , &H08 ' 74|1 , Report Size(8) =field size in bits = 1 byte
Data &H95 , &H04 ' 94|1:ReportCount
Data &HB1 , &H02 ' B0|1: Feature report
Data &HC0 ' C0|0 , End Collection
