This configuration statement configures the OPAMP (OPerational AMPlifier).
CONFIG OPAMP=ENABLED|DISABLED , OPTIONn=VALUEn
The options and values depend on the processor. Below is a list of options and values. There can be multiple OPAMP'S. The X indicates the number in the range from 0-2.
OPTION |
VALUE |
OPAMP |
- ENABLED to enable the OPAMP. - DISABLED to disable the OPAMP. |
TIME_BASE |
Controls the maximum value of a counter that counts CLK_PER cycles to achieve a time interval equal to or larger than 1 μs. It should be written with one less than the number of CLK_PER cycles that are equal to or larger than 1 μs. This is used for the internal timing of the warm up and settling times. |
INP_RANGE |
Selects the op amp input voltage range. - RAIL_TO_RAIL : The op amp input voltage range is rail-to-rail - REDUCED : The op amp input voltage range and power consumption are reduced |
OPAMPx_RUNMODE |
Run in standby mode. - DISABLED : the OPx is disabled when in standby sleep mode and its output driver is disabled. - ENABLED : the OPx will continue operating as configured in standby sleep mode. |
OPAMP0_ALWAYS_ON |
Controls whether the OPAMP is always on or not. - DISABLED : the OPx is not always on but can be enabled by the ENABLE EVENTx and disabled by the DISABLE EVENTx - ENABLED : the OPx is always on |
OPAMP0_EVENTS |
Controls event reception and generation. - DISABLED : No events are enabled for OPx - ENABLED : All events are enabled for OPx |
OPAMP0_OUTMODE |
Selects the output mode for the output driver - OFF : the output driver for OPx is disabled but this can overridden by the DRIVEx event - NORMAL : the output driver for OPx is enabled in NORMAL mode |
OPAMP0_MUXWIP |
Multiplexer for wiper. Selects the resistor ladder wiper (potentiometer) position - R1_15R_R2_1R : R1=15R , R2=1R - R1_14R_R2_2R : R1=14R , R2=2R - R1_12R_R2_4R : R1=12R , R2=4R - R1_8R_R2_8R : R1=8R , R2=8R - R1_6R_R2_10R : R1=6R , R2=10R - R1_4R_R2_12R : R1=4R , R2=12R - R1_2R_R2_14R : R1=2R , R2=14R - R1_1R_R2_15R : R1=1R , R2=15R |
OPAMP0_MUXBOT |
Selects the analog signal connected to the bottom resistor in the resistor ladder - OFF : multiplexer off - INP : positive input pin for OPx - INN : negative input pin for OPx - DAC : DAC output (DAC and DAC output buffer must be enabled) - LINKOUT : OPx-1 output. When selecting LINKOUT for OP0 MUXBOT is connected to the output of OP2 - GND : ground |
OPAMP0_MUXTOP |
Selects the analog signal connected to the top resistor in the resistor ladder - OFF : multiplexer off - OUT : OPx output - VDD : VDD |
OPAMP0_MUXNEG |
Selects which analog signal is connected to the inverting(-) input of OPx - INN : negative input pin for OPx - WIP : wiper from OPx resistor ladder - OUT : OPx output (unity gain) - DAC : DAC output (DAC and DAC output buffer must be enabled) |
OPAMP0_MUXPOS |
Selects which analog signal is connected to the non inverting(+) input of OPx - INP : positive input pin for OPx - WIP : wiper from OPx resistor ladder - DAC : DAC output (DAC and DAC output buffer must be enabled) - GND : ground - VDDDIV2 : VDD / 2 - LINKOUT : OPx-1 output. Only available for OP1 and OP2 - LINKWIP : wiper from OP0 resistor ladder. Setting only available for OP2
OPAMP0_SETTLE |
Specifies the number of microseconds allowed for the opamp to settle. This value together with the value in TIME_BASE is used by an internal timer to determine when to generate the READYx event and set the SETTLED flag in the OPx_STATUS register |
OPAMP0_CAL |
This value is a calibration value that adjusts the input offset voltage of the op amp. &H00 provides the most negative value of offset adjustment &H80 provides no offset adjustment, and &HFF provides the most positive value of offset adjustment |
REGMODE |
- OVERWITE : the entire register is updated. - PRESERVE : the register bits are preserved. See also the AVRX topic. |
The OPAMP has settings common for all OP's and each individual OPAMP (named OPx) has settings.
The following image from the datasheet shows a block diagram.
