CONFIG INPUTBIN NEW 2080
Top  Previous  Next
Configure INPUTBIN behavior
CONFIG INPUTBIN = extended
extended
This mode is the only mode. It allows to receive packets greater than 255 bytes.
The maximum packet size is 64 KB.
Because support for big packets requires more code, it is made optional.
You can not change between normal and extended mode dynamically. If you chose to use extended mode, this will be used for all your PRINTBIN code.
CONFIG PRINT , PRINTBIN , INPUTBIN , CONFIG PRINTBIN
$regfile = "m103def.dat"                                   ' specify the used micro
$crystal = 8000000                                         ' used crystal frequency
$baud = 19200                                               ' use baud rate
Config Inputbin = Extended
Dim A(1000)
Inputbin A(1) ; 1000
