CONFIG ACI
Top  Previous  Next
Configures the Analog Comparator.
CONFIG ACI = ON|OFF, COMPARE = ON|OFF, TRIGGER=TOGGLE|RISING|FALLING
ACI
Can be switched on or off
COMPARE
Can be on or off.
When switched ON, the TIMER1 in capture mode will trigger on ACI too.
TRIGGER
Specifies which comparator events trigger the analog comparator interrupts.
