USING RS485
Top  Previous  Next
RS485
RS485 is used for serial communication and well suited for transmission over large distances.
Similar to RS232 we need a level shifter.
rs485-exampleThe sample above uses a MEGA161 or MEGA162 which has 2 UARTS. This way you can have both a RS232 and RS485 interface.
The RS232 is used for debugging.
In order to test you need 2 or more similar circuits. One circuit would be the master.
The other(s) would be a slave.
The same hardware is used to test the MODBUS protocol. The bus need to be terminated at both ends with a resistor. 100 ohm is a typical used value.
The GND of both circuits may not be connected ! Only connect point A and B from both circuits. For industrial usage it is best to use an optical isolated level shifter.
Simple MASTER sample
$regfile = "m162def.dat"                                    ' specify the used micro
$crystal = 8000000
$baud = 19200                                               ' use baud rate
$hwstack = 42                                               ' default use 32 for the hardware stack
$swstack = 40                                               ' default use 10 for the SW stack
$lib "modbus.lbx"
Config Print1 = Portb.1 , Mode = Set              ' use portb.1 for the direction
Rs485dir Alias Portb.1
Config Rs485dir = Output
Rs485dir = 0   ' go to receive mode
Portc.0 = 1    ' a switch is connected to pinc.0 so activate pull up resistor
'             TX    RX
' COM0   PD.1   PD.0   monitor
' COM1   PB.3   PB.2   rs485
'            PB.1           data direction rs485
Config Com2 = 9600 , Synchrone = 0 , Parity = Even , Stopbits = 1 , Databits = 8 , Clockpol = 0  ' MUST MATCH THE SLAVE
'use OPEN/CLOSE for using the second UART
Open "COM2:" For Binary As #1
'dimension some variables
Dim B As Byte
Dim W As Word
Dim L As Long
W = &H4567   ' set some values
L = &H12345678
Print "RS-485 MODBUS master"
 If Pinc.0 = 0 Then                                       ' test button
    Waitms 500                                            ' delay since we want to send just 1 frame
    Print "send request to slave/server"            ' to debug terminal
   ' Print #1 , Makemodbus(2 , 3 , 8 , 2);                  'slave 2, function 3, start address 8, 2 bytes
   ' Print #1 , Makemodbus(2 , 6 , 8 , W);                 'slave 2, function 6, address 8  , value of w
     Print #1 , Makemodbus(b , 16 , 8 , L);                'send a long
 If Ischarwaiting(#1) <> 0 Then  'did we got something back?
   B = Waitkey(#1)  ' yes so get it
   Print Hex(b) ; ",";  ' print it
A slave would simply listen to data, and once enough data received, send it back.
The MODBUS slave code is available as a commercial add on.
