The USB-ISP Programmer is a special USB programmer that is fully compatible with BASCOM's advanced programmer options.
Since many new PC's and especial Laptop's do not have a parallel programmer anymore, MCS selected the USB-ISP programmer from EMBUD.
The drivers are located in the USB sub directory that is located in the BASCOM-AVR application folder.
When you connect the programmer, Windows (98, ME, 2000, XP) will recognize the new device automatically.
Then the Hardware wizard will be started :
Select 'No, not this time' and click Next, as there is no driver at Microsoft's web.
The Wiz will show :
You need to select 'Install from a list or specific location' and click Next.
You can specify the path of the USB driver. This is by default :
C:\Program Files\MCS Electronics\BASCOM-AVR\USB
Use the Browse-button to select it, or a different location, depending on your installation.
As the driver is not certified by Micros ft, you will see the following window:
You need to select 'Continue Anyway'. A restore point will be made if your OS supports this and the driver will be installed.
After installation you must see the following window :
After you press Finish you will see Windows can use the programmer :
In BASCOM , Options, Programmer you can select the new programmer now.
New models of the USB programmer allow to set the speed.
The USB-ISP programmer is very quick and supports all options that the Sample Electronics and STK200 programmers support. It is good replacement for the STK200.
When you use other USB devices that use the FTDI drivers, there might occur a problem. Manual install the drivers of these other devices, then install the USB-ISP driver.
