Executes one of several statement blocks depending on the value of an expression.
SELECT CASE var
CASE test1 : statements
[CASE test2 : statements ]
CASE ELSE : statements
END SELECT
Var |
Variable to test the value of |
Test1 |
Value to test for. |
Test2 |
You can test for conditions to like:
CASE IS > 2 :
Another option is to test for a range :
CASE 2 TO 5 :
'name : case.bas
'purpose : demonstrates SELECT CASE statement
'micro : Mega48
'suited for demo : yes
'commercial addon needed : no
Dim I As Byte 'dim variable
Dim S As String * 5 , Z As String * 5
Input "Enter value (0-255) " , I
Select Case I
Case 1 : Print "1"
Case 2 : Print "2"
Case 3 To 5 : Print "3-5"
Case Is >= 10 : Print ">= 10"
Case Else : Print "Not in Case statement"
End Select
'note that a Boolean expression like > 3 must be preceded
'by the IS keyword
