With this option you can modify the programmer settings.
OPTION |
DESCRIPTION |
Programmer |
Select one from the list. |
Play sound |
Name of a WAV file to be played when programming is finished.
Press the directory button to select a file. |
Erase Warning |
Set this option when you want a confirmation when the chip is erased. |
Auto flash |
Some programmers support auto flash. Pressing F4 will program the chip without showing the programmer window. |
Auto verify |
Some programmers support verifying. The chip content will be verified after programming. |
Upload code and data |
Set this option to program both the FLASH memory and the EEPROM memory |
Program after compile |
When compilation is successful, the chip will be programmed |
Set focus to terminal emulator |
When the chip is programmed, the terminal emulator will be shown |
Parallel printer port programmers |
LPT address |
Port address of the LPT that is connected to the programmer. |
Port delay |
An optional delay in uS. It should be 0. But on some systems a delay might be needed. |
Serial port programmer |
COM port |
The com port the programmer is connected to. |
STK500 EXE |
The path of stk500.exe. This is the full file location to the files stk500.exe that comes with the STK500. |
USB |
For mkII and other Atmel USB programmers you can enter the serial number here. Or you can look it up from the list. |
Other |
Use HEX |
Select when a HEX file must be sent instead of the bin file. |
Program |
The program to execute. This is your programmer software. |
Parameter |
The optional parameter that the program might need.
Use {FILE} to insert the binary filename(file.bin) and {EEPROM} to insert the filename of the generated EEP file.
When ‘Use Hex’ is checked the filename (file.hex) will be inserted for {FILE}. In all cases a binary file will be inserted for {EEPROM} with the extension .EEP
Use {CHIP} to insert the official device name of the chip. The device name is required by some programmers. |
See Also
