The FP_TRIG library is written by Josef Franz Vögel.
All trig functions are stored in fp_trig.lib library.
The fp_trig.lbx contains the compiled object code and is used by BASCOM.
This sample demonstrates all the functions from the library:
'name : test_fptrig2.bas
'purpose : demonstates FP trig library from Josef Franz Vögel
'micro : Mega8515
'suited for demo : no
'commercial addon needed : no
$regfile = "m8515.dat" ' specify the used micro
Dim S1 As Single , S2 As Single , S3 As Single , S4 As Single , S5 As Single , S6 As Single
Dim Vcos As Single , Vsin As Single , Vtan As Single , Vatan As Single , S7 As Single
Dim Wi As Single , B1 As Byte
Dim Ms1 As Single
Const Pi = 3.14159265358979
'calculate PI
Ms1 = Atn(1) * 4
Testing_power:
Print "Testing Power X ^ Y"
Print "X Y x^Y"
For S1 = 0.25 To 14 Step 0.25
S2 = S1 \ 2
S3 = Power(s1 , S2)
Print S1 ; " ^ " ; S2 ; " = " ; S3
Print : Print : Print
Testing_exp_log:
Print "Testing EXP and LOG"
Print "x exp(x) log([exp(x)]) Error-abs Error-rel"
Print "Error is for calculating exp and back with log together"
For S1 = -88 To 88
S2 = Exp(s1)
S3 = Log(s2)
S4 = S3 - S1
S5 = S4 \ S1
Print S1 ; " " ; S2 ; " " ; S3 ; " " ; S4 ; " " ; S5 ; " " ;
Testing_trig:
Print "Testing COS, SIN and TAN"
Print "Angle Degree Angle Radiant Cos Sin Tan"
For Wi = -48 To 48
S1 = Wi * 15
S2 = Deg2rad(s1)
Vcos = Cos(s2)
Vsin = Sin(s2)
Vtan = Tan(s2)
Print S1 ; " " ; S2 ; " " ; Vcos ; " " ; Vsin ; " " ; Vtan
Testing_atan:
Print "Testing Arctan"
Print "X atan in Radiant, Degree"
S1 = 1 / 1024
S2 = Atn(s1)
S3 = Rad2deg(s2)
S1 = S1 * 2
If S1 > 1000000 Then
Exit Do
Testing_int_fract:
Print "Testing Int und Fract of Single"
Print "Value Int Frac"
S2 = Pi \ 10
For S1 = 1 To 8
S3 = Int(s2)
S4 = Frac(s2)
Print S2 ; " " ; S3 ; " " ; S4
S2 = S2 * 10
Print "Testing degree - radiant - degree converting"
Print "Degree Radiant Degree Diff-abs rel"
For S1 = 0 To 90
S2 = Deg2rad(s1)
S3 = Rad2deg(s2)
S4 = S3 - S1
S5 = S4 \ S1
Testing_hyperbolicus:
Print "Testing SINH, COSH and TANH"
Print "X sinh(x) cosh(x) tanh(x)"
For S1 = -20 To 20
S3 = Sinh(s1)
S2 = Cosh(s1)
S4 = Tanh(s1)
Print S1 ; " " ; S3 ; " " ; S2 ; " " ; S4
Testing_log10:
Print "Testing LOG10"
Print "X log10(x)"
S1 = 0.01
S2 = Log10(s1)
Print S1 ; " " ; S2
S1 = 0.1
S2 = Log10(s1)
Print S1 ; " " ; S2
For S1 = 1 To 100
S2 = Log10(s1)
Print S1 ; " " ; S2
'test MOD on FP
S1 = 10000
S2 = 3
S3 = S1 Mod S2
Print S3
Print "Testing_SQR-Single"
For S1 = -1 To 4 Step 0.0625
S2 = Sqr(s1)
Print S1 ; " " ; S2
For S1 = 1000000 To 1000100
S2 = Sqr(s1)
Print S1 ; " " ; S2
Testing_atn2:
Print "Testing Sin / Cos / ATN2 / Deg2Rad / Rad2Deg / Round"
Print "X[deg] X[Rad] Sin(x) Cos(x) Atn2 Deg of Atn2 Rounded"
For S1 = -180 To 180 Step 5
S2 = Deg2rad(s1)
S3 = Sin(s2)
S4 = Cos(s2)
S5 = Atn2(s3 , S4)
S6 = Rad2deg(s5)
S7 = Round(s6)
Print S1 ; " " ; S2 ; " " ; S3 ; " " ; S4 ; " " ; S5 ; " " ; S6 ; " " ; S7
Print "note: -180° is equivalent to +180°"
Testing_asin_acos:
Print "Testing ASIN, ACOS"
Print "X asin(x) acos(x)"
For S1 = -1.125 To 1.125 Step 0.0625
S2 = Asin(s1)
S3 = Acos(s1)
Print "Note: > 1.0 and < -1.0 are invalid and shown here for error handling"
Testing_shift:
S1 = 12
For B1 = 1 To 20
S2 = S1 : S3 = S1
Shift S2 , Left , B1
Shift S3 , Right , B1
Print "End of testing"
