Declares a subroutine.
DECLARE SUB TEST[( [BYREF/BYVAL/BYLABEL] var as type)]
test |
Name of the procedure. |
Var |
Name of the variable(s). |
Type |
Type of the variable(s). Byte, Word, Dword, Integer, Long, Single, Double or String. |
When BYREF or BYVAL is not provided, the parameter will be passed by reference.
Use BYREF to pass a variable by reference with its address. When using the referenced address, you work on the original variable. So a change of the variable inside the sub routine, will change the variable outside the routine as well.
Use BYVAL to pass a copy of the variable. Passing a copy of the variable allows to alter the copy in the sub routine while leaving the original variable unaltered. BYVAL will not change the original passed variable but it requires more code since a copy of the parameter must be created.
Use BYLABEL to pass the address of a label. BYLABEL will pass the word address. It will not work for processors with multiple 64 KB pages.
Using BYLABEL on the EEPROM is possible but the EEPROM image must proceed the call with the label name.
See also READEEPROM, LOADLABE and Memory usage
If you pass a string you may specify the length of the string. This length will be the maximum length the string may grow. This is important when you pass a string BYVAL.
When you for example pass a string like "ABC" to a subroutine or function BYVAL, the compiler will create a copy with a length of 3. This is sufficient to pass it to the sub routine.
But if the sub routine adds data to the string, it will not fit since the string is too short. In such a case you can specify the length. s as string * 10, will create a string with a size of 10.
See the CALL statement for more details.
You must declare each function before writing the function or calling the function. And the declaration must match the function.
Bits are global and can not be passed with functions or subs.
CALL, SUB , FUNCTION , CONFIG SUBMODE
'name : declare.bas
'purpose : demonstrate using declare
'micro : Mega48
'suited for demo : yes
'commercial addon needed : no
'Try a SUB without parameters
Declare Sub Test2
'the subprogram
Dim Ar(10) As Byte
For Bb = 1 To 10
Bb = 1
Call Teststr(bb , Sar(1))
Call Test2 'call sub
Test2 'or use without CALL
Bb = 1
Print Bb ; I ; W ; L ; S
'now pass an array
Testarray 2 , Ar(1)
Print "ar(1) = " ; Ar(1)
Print "ar(3) = " ; Ar(3)
Testvar Bb , I , I , I , S
$typecheck 'turn it back on
B1 = 3 'change value
End Sub
Print "No parameters"
End Sub
Local X As Byte
X = 5 'assign local
B = X
I = -1
W = 40000
L = 20000
S = "test"
End Sub
End Sub
Dl(b) = Dl(b) + "add"
End Sub
Example BYLABEL
$regfile = "m88def.dat"
$hwstack = 40
$swstack = 80
$framesize = 80
Dim B As Byte , W As Word
Declare Sub Somesub(bylabel Mylabel As Word)
Somesub Alabel
W = Mylabel ' this points to the BYTE address of the data
lds _dptrl,{W } ' point to
LDS _dptrh,{W+1}
Read B : Print B
End Sub
Alabel:
Data 1 , 2 , 3
