$CRYSTAL
Top  Previous  Next
Instruct the compiler to override the crystal frequency options setting.
$CRYSTAL = var
var
A numeric constant with the Frequency of the crystal.
The frequency is selectable from the Compiler Settings. It is stored in a configuration file. The $CRYSTAL directive overrides this setting.
It is best to use the $CRYSTAL directive as the used crystal frequency is visible in your program that way.
notice The $CRYSTAL directive only informs the compiler about the used frequency. It does not set any fuse bit. The frequency must be know by the compiler for a number of reasons. First when you use serial communications, and you specify $BAUD, the compiler can calculate the proper settings for the UBR register. And second there are a number of routines like WAITMS, that use the execution time of a loop to generate a delay. When you specify $CRYSTAL = 1000000 (1 MHz) but in reality, connect a 4 MHz XTAL, you will see that everything will work 4 times as quick.
Most new AVR chips have an internal oscillator that is enabled by default. Check the data sheet for the default value.
$BAUD , BAUD , CONFIG CLOCKDIV
$regfile = "m48def.dat"
$crystal = 4000000
$baud = 19200
Print "Hello world"
