CONFIG X10
Top  Previous  Next
Configures the pins used for X10.
CONFIG X10 = pinZC , TX = portpin
PinZC
The pin that is connected to the zero cross output of the TW-523. This is a pin that will be used as INPUT.
Portpin
The pin that is connected to the TX pin of the TW-523.
TX is used to send X10 data to the TW-523. This pin will be used in output mode.
The TW-523 RJ-11 connector has the following pinout:
Pin
Description
Connect to micro
1
Zero Cross
Input pin. Add 5.1K pull up.
2
GND
GND
3
RX
Not used.
4
TX
Output pin. Add 1K pull up.
X10DETECT , X10SEND
'name                     : x10.bas
'copyright                : (c) 1995-2005, MCS Electronics
'purpose                  : example needs a TW-523 X10 interface
$regfile = "m48def.dat"                                   ' specify the used micro
$crystal = 8000000                                         ' used crystal frequency
$baud = 19200                                               ' use baud rate
'define the house code
Const House = "M"                                         ' use code A-P
Waitms 500                                                 ' optional delay not really needed
'dim the used variables
Dim X As Byte
'configure the zero cross pin and TX pin
Config X10 = Pind.4 , Tx = Portb.0
'             ^--zero cross
'                           ^--- transmission pin
'detect the TW-523
X = X10detect()
Print X                                                     ' 0 means error, 1 means 50 Hz, 2 means 60 Hz
Input "Send (1-32) " , X
'enter a key code from 1-31
'1-16 to address a unit
'17 all units off
'18 all lights on
'19 ON
'20 OFF
'21 DIM
'22 BRIGHT
'23 All lights off
'24 extended code
'25 hail request
'26 hail acknowledge
'27 preset dim
'28 preset dim
'29 extended data analog
'30 status on
'31 status off
'32 status request
X10send House , X                                       ' send the code
Dim Ar(4) As Byte
X10send House , X , Ar(1) , 4                               ' send 4 additional bytes
