CONFIG VPORT
Top  Previous  Next
Maps an XMEGA port to a virtual port.
CONFIG VPORT0 = port  [, VPORT1=port, VPORT2=port, VPORT3=port]
VPORT
There are 4 virtual port registers. When setting up these registers, you need to use VPORTx, where X is 0,1,2 or 3, indicating the virtual port.
The virtual port itself is accesed via it's registers PORTy, PINy and DDRy where Y is a 0,1 ,2 or 3.
The normal ports have named like PORTA, PORTB, etc.
A virtual port will access the same port but using a different register.
port
The last letter of the real port name. For example A for PORTA, B for PORTB, C for PORTC etc.
All ports in the Xmega are located in the extended address area. This space can only be accessed with instructions like LDS,STS, LD and ST.
Special bit instructions only work on the lower IO-registers.
Xmega example :
again:
Lds r24, PINA   ; read port input value
sbrs r24,7       ; skip next instruction if bit 7 is set (1)
rjmp again       ; try again
Now the same code for a normal AVR
again:
sbis PINA,7      ; skip if pina.7 is set
rjmp again
Not only less code is required, but the LDS takes 3 cycles
With the virtual mapping, you can access any PORT register (PORT,PIN and DDR) via it's virtual name PORT0, PIN0 or DDR0.
Since there are 4 virtual mapping registers, you can define PORT0, PORT1, PORT2 and PORT3.
When you write to PORTn, the compiler can use the smaller/quicker code.
Devices like graphical LCD can benefit from this.
See Also
CONFIG PORT
'                  (c) 1995-2010, MCS
'           Mapping Real Ports to Virtual Ports.bas
'  This sample demonstrates mapping ports to virtual ports
'  based on MAK3's sample
$regfile = "xm128a1def.dat"
$crystal = 32000000
$hwstack = 64
$swstack = 40
$framesize = 40
$lib "xmega.lib"
$external _xmegafix_clear
$external _xmegafix_rol_r1014
'configure the systemclock
Print "Map VPorts"
'map portD to virtual port0, map portE to virtual port1, map portC to virtual port2
'map portR to virtual port 3
Config VPort0 = D , VPort1 = E , VPort2 = C , VPort3 = R
'Each virtual port is available as PORT0, PORT1, PORT2 and PORT3
'      data direct is available as DDR0 , DDR1,  DDR2  and DDR3
'        PIN input is available as PIN0 , PIN1,  PIN2  and PIN3
'The advantage of virtual port registers is that shorter asm instruction can be used which also use only 1 cycle
Dim Var As Byte
'Real Port Direction
Ddr1 = &B0000_0000                                         ' Port E = INPUT
Ddr0 = &B1111_1111                                         ' Port D = OUTPUT
'Continously copy the value from PORTE to PORTD using the virtual ports.
   Var = Pin1                                             'Read Virtual Port 0
   Port0 = Var                                             'Write Virtual Port 1
End                                                         'end program
