CONFIG TWI
Top  Previous  Next
Configure the TWI (two wire serial interface).
CONFIG TWI = clockspeed
CONFIG TWIC | TWID | TWIE | TWIF = clockspeed
clockspeed
The desired clock frequency for SCL
CONFIG TWI will set TWSR pre scaler bits 0 and 1, and TWBR depending on the used $CRYSTAL frequency and the desired SCL clock speed.
Typical you need a speed of 400 KHz. Some devices will work on 100 KHz as well.
When TWI is used in SLAVE mode, you need to have a faster clock speed as the master.
XMEGA
The XMEGA can contain up to 4 TWI units. When not specifying TWIC, TWID, TWIE or TWIF, the TWIC will be used as  the default.
You MUST dimension a variable named TWI_START as a byte. It is used by the xmega TWI library code. Without it, you will get an error.
notice It is important that you specify the proper crystal frequency. Otherwise it will result in a wrong TWI clock frequency.
$CRYSTAL , OPEN
' (c) 2004 MCS Electronics
' This demo shows an example of the TWI
' Not all AVR chips have TWI (hardware I2C)
'The chip will work in TWI/I2C master mode
'Connected is a PCF8574A 8-bits port extender
$regfile="M8def.dat"' the used chip
$crystal= 4000000 ' frequency used
$baud= 19200 ' baud rate
$lib"i2c_twi.lbx"' we do not use software emulated I2C but the TWI
Config Scl =Portc.5 ' we need to provide the SCL pin name
Config Sda =Portc.4 ' we need to provide the SDA pin name
'On the Mega8, On the PCF8574A
'scl=PC5 , pin 28 pin 14
'sda=PC4 , pin 27 pin 15
I2cinit' we need to set the pins in the proper state
Config Twi = 100000 ' wanted clock frequency
'will set TWBR and TWSR
'Twbr = 12 'bit rate register
'Twsr = 0 'pre scaler bits
Dim B AsByte, X AsByte
Print"TWI master"
Incr B ' increase value
I2csend&B01110000 , B ' send the value
Print"Error : ";Err' show error status
I2creceive&B01110000 , X ' get a byte
Print X ;" ";Err' show error
Waitms 500 'wait a bit
