Configure TIMER2.
Syntax for the 8535
CONFIG TIMER2 = TIMER | PWM , ASYNC=ON |OFF,
PRESCALE = 1 | 8 | 32 | 64 | 128 | 256 | 1024 ,
COMPARE = CLEAR | SET | TOGGLE | DISCONNECT ,
PWM = ON | OFF ,
COMPARE_PWM = CLEAR_UP| CLEAR_DOWN | DISCONNECT ,
CLEAR_TIMER = 1|0
[,CONFIGURATION=NAME]
Syntax for the M103
CONFIG TIMER2 = COUNTER| TIMER | PWM ,
EDGE= FALLING |RISING,
PRESCALE = 1 | 8 | 64 | 256 | 1024 ,
PWM = ON | OFF ,
COMPARE_PWM = CLEAR UP| CLEAR DOWN | DISCONNECT ,
CLEAR _IMER = 1|0
The TIMER2 is an 8 bit counter.
It depends on the chip if it can work as a counter or not.
The syntax shown above must be on one line. Not all the options need to be selected.
Here is the effect of the various options.
EDGE |
You can select whether the TIMER will count on the falling or rising edge. Only for COUNTER mode. |
PRESCALE |
The TIMER is connected to the system clock in this case. You can select the division of the system clock with this parameter.
Valid values are 1 , 8, 64, 256 or 1024 or 1 , 8, 32 , 64 , 256 or 1024 for the M103
Prescale can not be used in COUNTER mode. |
The TIMER2 also has a compare registers
When the timer value matches a compare register, an action can be performed
COMPARE |
The action can be:
SET will set the OC2 pin CLEAR will clear the OC2 pin TOGGLE will toggle the OC2 pin DISCONNECT will disconnect the TIMER from output pin OC2 |
And the TIMER can be used in 8 bit PWM mode
You can specify if the counter must count UP or down after a match to the compare registers
COMPARE PWM |
PWM compare mode. Can be CLEAR_UP or CLEAR_DOWN |
CONFIGURATION is optional. When you add configuration=mysetting, you can use this setting when you start the timer : START TIMER0 , mysetting
If you have multiple settings, you can start the timer with these different settings.
Dim W As Byte
Config Timer2 = Timer , ASYNC = 1 , Prescale = 128
On TIMER2 Myisr
ENABLE INTERRUPTS
ENABLE TIMER2
DO
LOOP
MYISR:
'get here every second with a 32768 Hz xtal
RETURN
'You can read or write to the timer with the COUNTER2 or TIMER2 variable
W = Timer2
Timer2 = W
