Configures how much servo’s will be controlled.
CONFIG SERVOS = X , Servo1 = Portb.0 , Servo2 = Portb.1 , Reload = rl , INTERVAL=t
Servo’s need a variable pulse in order to operate. The CONFIG SERVOS directive will set up a byte array with the servo pulse width values and will initialize an ISR that uses TIMER0.
X |
The number of servo’s you want to control. Each used servo will use one byte of SRAM. |
servox |
The port pin the servo is attached too. |
reload |
The reload value for the ISR in uS. |
Interval |
The update interval. Using the interval option will result in using alternative servo code optimized for servos. |
When you use for example :
Config Servos = 2 , Servo1 = Portb.0 , Servo2 = Portb.1 , Reload = 10
The internal ISR will execute every 10 uS.
An arrays named SERVO() will be created and it can hold 2 bytes : servo(1) and servo(2).
By setting the value of the servo() array you control how long the positive pulse will last. After it has reached this value it will be reset to 0.
The reload value should be set to 10. After 20 mS, a new pulse will be generated.
You can use other reload values but it will also mean that the repeat value will change.
The PORT pins specified must be set to work as an output pin by the user.
CONFIG PINB.0 = OUTPUT
Will set a pin to output mode.
The CONFIG SERVOS only works with servo's that rotate 180 degrees. These are the servo's found in RC models.
There are also continuous rotation servos which work different. The servo code will NOT work on these servos.
Alternative Servocode
When using the INTERVAL option, you can use alternative code which is optimized for servo's.
You should use a RELOAD value of 100 in that case and an interval of 100 should be used for best results.
Using a reload of 100 uS will give more time to the main application. This does give lower resolution but this is not a problem for most model servos. With an interval of 100, the refresh will be done in 100x100 us which results in 10 mS.
The following test code was used:
Config Servos = 2 , Servo1 = Portd.7 , Servo2 = Portb.1 , Reload = 100 , Interval = 100
Servo(1) = 10
Servo(2) = 5
For J = 8 To 16
Servo(1) = J
Waitms 5000 ' some time to check if the servo is stable
Waitms 5000
Resources used
TIMER0 is used to create the ISR.
'name : servos.bas
'purpose : demonstrates the SERVO option
'micro : 90S2313
'suited for demo : yes
'commercial addon needed : no
'Servo's need a pulse in order to operate
'with the config statement CONFIG SERVOS we can specify how many servo's we
'will use and which port pins are used
'A maximum of 14 servos might be used
'The SERVO statements use one byte for an interrupt counter and the TIMER0
'This means that you can not use TIMER0 anymore
'The reload value specifies the interval of the timer in uS
'Config Servos = 2 , Servo1 = Portb.0 , Servo2 = Portb.1 , Reload = 10
Config Servos = 1 , Servo1 = Portb.0 , Reload = 10
'as an option you can use TIMER1
'Config Servos = 2 , Servo1 = Portb.0 , Servo2 = Portb.1 , Reload = 10 , Timer = Timer1
'we use 2 servos with 10 uS resolution(steps)
'we must configure the port pins used to act as output
Config Portb = Output
'finally we must turn on the global interrupt
'the servo() array is created automatic. You can used it to set the
'time the servo must be on
Servo(1) = 10 '10 times 10 = 100 uS on
'Servo(2) = 20 '20 times 10 = 200 uS on
Dim I As Byte
For I = 0 To 100
Servo(1) = I
Waitms 1000
For I = 100 To 0 Step -1
' Servo(1) = I
Waitms 1000
