Configures the hardware UART to use a buffer for input
CONFIG SERIALIN | SERIALIN1 | SERIALIN2 | SERIALIN3 = BUFFERED , SIZE = size [, BYTEMATCH=ALL|BYTE|NONE] [,CTS=pin, RTS=pin , Threshold_full=num , Threshold_empty=num ]
SerialIn |
Some chips have multiple HW UARTS. Use the following parameter values:
Size |
A numeric constant that specifies how large the input buffer should be. The space is taken from the SRAM. The maximum is 255. |
Bytematch |
The ASCII value of the byte that will result in calling a user label. When you specify ALL, the user label will be called for every byte that is received. You must include the label yourself in your code and end it with a return. The following label names must be used when you check for a specific byte value:
The following label names must be used when you check for any value:
When you specify NONE, it is the same as not specifying this optional parameter. |
CTS |
The pin used for the CTS.(Clear to send). For example PIND.6 |
RTS |
The pin used for RTS. (Ready to send). For example PIND.7 |
Threshold_full |
The number of bytes that will cause RTS to be set to '1'. This is an indication to the sender, that the buffer is full. |
Threshold_empty |
The number of free bytes that must be in the buffer before CTS may be made '0' again. |
The following internal variables will be generated for UART0:
_RS_HEAD_PTR0 , a byte counter that stores the head of the buffer
_RS_TAIL_PTR0 , a byte counter that stores the tail of the buffer.
_RS232INBUF0 , an array of bytes that serves as a ring buffer for the received characters.
_RS_BUFCOUNTR0, a byte that holds the number of bytes that are in the buffer.
For the other UARTS, the variables are named similar. But they do have a different number.
A 1 for the second UART, a 3 for the third UART and a 4 for the fourth UART. Yes, the '2' is skipped.
While you can read and write the internal variables, we advise not to write to them. The variables are updated inside interrupts routines, and just when you write a value to them, an ISR can overwrite the value.
The optional BYTEMATCH can be used to monitor the incoming bytes and call a label when the specified label is found. This label is a fixed label as mentioned in the table above.
This way you can determine the start of a serial stream.
While bytematch allows you to trap the incoming bytes, take care that you do not delay the program execution too much. After all the serial input interrupt is used in order not to miss incoming data. When you add delays or code that will delay execution too much you might loose incoming data.
When using the BYTEMATCH option, you must preserve the registers you alter. If you do not know which one, use PUSHALL and POPALL.
To clear the buffer, use CLEAR SERIALIN. Do not read and write the internal buffer variables yourself.
CTS-RTS is hardware flow control. Both the sender and receiver need to use CTS-RTS when CTS-RTS is used. When one of the parties does not use CTS-RTS, no communication will be possible.
CTS-RTS use two extra lines. The receiver must check the CTS pin to see if it may send. The CTS pin is a input pin as the receiver looks at the level that the sender can change.
The receiver can set the RTS pin to indicate to the sender that it can accept data.
In the start condition, RTS is made '0' by the receiver. The sender will then check this logic level with it's CTS pin, and will start to send data. The receiver will store the data into the buffer and when the buffer is almost full, or better said, when the Threshold_full is the same as the number of bytes in the receive buffer, the receiver will make RTS '1' to signal to the sender, that the buffer is full. The sender will stop sending data. And will continue when the RTS is made '0' again.
The receiver can send data to the sender and it will check the CTS pin to see if it may send data.
In order to work with CTS-RTS, you need both a serial input buffer, and a serial output buffer. So use both CONFIG SERIALIN and CONFIG SERIALOUT to specify the buffers.
The CTS-RTS can only be configured with the CONFIG SERIALIN statement.
The thresholds are needed for high baud rates where it will take some time to react on a CTS-RTS.
You need to experiment with the thresholds but good start values are 80% full, and 20% empty.
You need to use a pin that is bit addressable. For most chips this is a pin from port A, B,C or D.
Routines called from MCS.LIB :
_GotChar. This is an ISR that gets called when ever a character is received.
When there is no room for the data it will not be stored.
So the buffer must be emptied periodic by reading from the serial port using the normal statements like INKEY() and INPUT.
Since URXC interrupt is used by _GotChar, you can not use this interrupt anymore. Unless you modify the _gotchar routine of course.
CONFIG SERIALOUT , ISCHARWAITING , CLEAR
'name : rs232buffer.bas
'purpose : example shows the difference between normal and buffered
' serial INPUT
'micro : Mega161
'suited for demo : yes
'commercial addon needed : no
$regfile = "m161def.dat" ' specify the used micro
$baud = 9600 ' use baud rate
'first compile and run this program with the line below remarked
Config Serialin = Buffered , Size = 20
Dim Na As String * 10
'the enabling of interrupts is not needed for the normal serial mode
'So the line below must be remarked to for the first test
Print "Start"
'get a char from the UART
If Ischarwaiting() = 1 Then 'was there a char?
Input Na
Print Na 'print it
Wait 1 'wait 1 second
'You will see that when you slowly enter characters in the terminal emulator
'they will be received/displayed.
'When you enter them fast you will see that you loose some chars
'NOW remove the remarks from line 11 and 18
'and compile and program and run again
'This time the chars are received by an interrupt routine and are
'stored in a buffer. This way you will not loose characters providing that
'you empty the buffer
'So when you fast type abcdefg, they will be printed after each other with the
'1 second delay
'Using the CONFIG SERIAL=BUFFERED, SIZE = 10 for example will
'use some SRAM memory
'The following internal variables will be generated :
'_Rs_head_ptr0 BYTE , a pointer to the location of the start of the buffer
'_Rs_tail_ptr0 BYTE , a pointer to the location of tail of the buffer
'_RS232INBUF0 BYTE ARRAY , the actual buffer with the size of SIZE
Example2
'name :
'copyright : (c) 1995-2008, MCS Electronics
'purpose : test for M2560 support
'micro : Mega2560
$regfile = "m2560def.dat" ' specify the used micro
$hwstack = 40 ' default use 32 for the hardware stack
'$timeout = 1000000
'The M128 has an extended UART.
'when CO'NFIG COMx is not used, the default N,8,1 will be used
Config Com1 = 19200 , Synchrone = 0 , Parity = None , Stopbits = 1 , Databits = 8 , Clockpol = 0
Config Com3 = 19200 , Synchrone = 0 , Parity = None , Stopbits = 1 , Databits = 8 , Clockpol = 0
Config Com4 = 19200 , Synchrone = 0 , Parity = None , Stopbits = 1 , Databits = 8 , Clockpol = 0
Config Serialin1 = Buffered , Size = 20 , Bytematch = 65
Config Serialin2 = Buffered , Size = 20 , Bytematch = 66
Config Serialin3 = Buffered , Size = 20 , Bytematch = All
'Open all UARTS
Open "COM2:" For Binary As #2
Open "COM3:" For Binary As #3
Open "COM4:" For Binary As #4
Print "Hello" 'first uart
Dim B1 As Byte , B2 As Byte , B3 As Byte , B4 As Byte
Dim Tel As Word , Nm As String * 16
'unremark to test second UART
'Input #2 , "Name ?" , Nm
'Print #2 , "Hello " ; Nm
Incr Tel
Print Tel ; " test serial port 1"
Print #2 , Tel ; " test serial port 2"
Print #3 , Tel ; " test serial port 3"
Print #4 , Tel ; " test serial port 4"
B1 = Inkey() 'first uart
B2 = Inkey(#2)
B3 = Inkey(#3)
B4 = Inkey(#4)
If B1 <> 0 Then
Print B1 ; " from port 1"
If B2 <> 0 Then
Print #2 , B2 ; " from port 2"
If B3 <> 0 Then
Print #3 , B3 ; " from port 3"
If B4 <> 0 Then
Print #4 , B4 ; " from port 4"
Waitms 500
'Label called when UART2 received an A
Serial1charmatch:
Print #2 , "we got an A"
'Label called when UART2 received a B
Serial2charmatch:
Print #3 , "we got a B"
'Label called when UART3 receives a char
Serial3bytereceived:
Print #4 , "we got a char"
Close #2
Close #3
Close #4
$eeprom
Data 1 , 2
