CONFIG SDA
Top  Previous  Next
Overrides the SDA pin assignment from the Option Compiler Settings.
CONFIG SDA = pin
Pin
The port pin to which the I2C-SDA line is connected.
When you use different pins in different projects, you can use this statement to override the Options Compiler setting for the SDA pin. This way you will remember which pin you used because it is in your code and you do not have to change the settings from the options. In BASCOM-AVR the settings are also stored in the project.CFG file.
When using the Hardware TWI, you only need CONFIG SDA when you use the I2CINIT statement
CONFIG SCL , CONFIG I2CDELAY , I2CINIT
CONFIG SDA = PORTB.7  'PORTB.7 is the SDA line
