Overrides the SCL pin assignment from the Option Compiler Settings.
CONFIG SCL = pin
Pin |
The port pin to which the I2C-SCL line is connected. |
When you use different pins in different projects, you can use this statement to override the Options Compiler setting for the SCL pin. This way you will remember which pin you used because it is in your code and you do not have to change the settings from the options. Of course BASCOM-AVR also stores the settings in a project.CFG file.
When using the Hardware TWI, you only need CONFIG SCL when you use the I2CINIT statement
CONFIG SDA , CONFIG I2CDELAY , I2CINIT
CONFIG SCL = PORTB.5 'PORTB.5 is the SCL line
