CONFIG RC5
Top  Previous  Next
Overrides the RC5 pin assignment from the Option Compiler Settings.
CONFIG RC5 = pin [,TIMER=2] [,WAIT=value]
Pin
The port pin to which the RC5 receiver is connected.
TIMER
Must be 2. The micro must have a timer2 when you want to use this option. This additional parameter will cause that TIMER2 will be used instead of the default TIMER0.
WAIT
The default value is 100. Each unit is ca. 64 us. This gives a time out of 6.4 ms.  Since a start bit is 3.5 ms, you can reduce the value to 56. When you make it lower, it will not work.
When you want the old behavior you need to specify a value of 2000 which is ca. 131 ms.
When you use different pins in different projects, you can use this statement to override the Options Compiler setting for the RC5 pin. This way you will remember which pin you used because it is in your code and you do not have to change the settings from the options. In BASCOM-AVR the settings are also stored in the project.CFG file.
GETRC5
CONFIG RC5 = PIND.5  'PORTD.5 is the RC5 input line
