CONFIG LCDPIN
Top  Previous  Next
Override the LCD-PIN select options.
CONFIG LCDPIN = PIN , DB4= PN,DB5=PN, DB6=PN, DB7=PN, E=PN, RS=PN  [WR=PIN] [BUSY=PIN] [MODE=mode]
CONFIG LCDPIN = PIN , PORT=PORTx, E=PN, RS=PN
PN
The name of the PORT pin such as PORTB.2 for example.
PORTX
When you want to use the LCD in 8 bit data, pin mode, you must specify the PORT to use.
PIN
A port pin that is connected to the busy pin. The busy pin is only supported by the 20x4VFD display.
MODE
A mode for the 20x4VFD display. Options :
0 : 4 bit parallel upper nibble first
1 : 4 bit parallel lower nibble first
You can override the PIN selection from the Compiler Settings with this statement, so a second configuration lets you not choose more pins for a second LCD display.
The config command is preferred over the option settings since the code makes clear which pins are used. The CONFIG statement overrides the Options setting.
The PIN and MODE are only for the 20x4VFD display. See also LCDAUTODIM
The WR pin is optional. When you select the WR pin, an alternative library will be used. This library uses the WR pin and reads the BUSY signal from the LCD.
The library lcd4busy_anypin will be used, which is based on Luciano's LUC_lcd4busy library.
Notice that since 2040 version, the compiler will generate LCD port pin info which you can use for your own libs.
By default the WR pin is optional and the WR signal of the LCD should be connected to ground. This saves the pin for other purposes. When you have enough pins, you better use the WR-pin.
If you do not connect the WR pin to ground but to a pin, and you do not specify the WR pin, but you set the logic level to 0 in your code, you have to use an INITLCD command after you have set the WR pin to 0.
CONFIG LCD , CONFIG LCDMODE , CONFIG LCDBUS
'name                     : lcd.bas
'copyright                : (c) 1995-2005, MCS Electronics
'purpose                  : demo: LCD, CLS, LOWERLINE, SHIFTLCD, SHIFTCURSOR, HOME
'                           CURSOR, DISPLAY
'micro                    : Mega8515
$regfile = "m8515.dat"                                     ' specify the used micro
$crystal = 4000000                                         ' used crystal frequency
$baud = 19200                                               ' use baud rate
$sim
'REMOVE the above command for the real program !!
'$sim is used for faster simulation
'note : tested in PIN mode with 4-bit
'These settings are for the STK200 in PIN mode
'Connect only DB4 to DB7 of the LCD to the LCD connector of the STK D4-D7
'Connect the E-line of the LCD to A15 (PORTC.7) and NOT to the E line of the LCD connector
'Connect the RS, V0, GND and =5V of the LCD to the STK LCD connector
Dim A As Byte
Config Lcd = 16x2                                         'configure lcd screen
'other options are 16 * 4 and 20 * 4, 20 * 2 , 16 * 1a
'       use this with uP with external RAM and/or ROM
'       because it aint need the port pins !
Cls                                                       'clear the LCD display
Lcd "Hello world."                                         'display this at the top line
Wait 1
Lowerline                                                 'select the lower line
Wait 1
Lcd "Shift this."                                         'display this at the lower line
Wait 1
For A = 1 To 10
Shiftlcd Right                                         'shift the text to the right
Wait 1                                                   'wait a moment
For A = 1 To 10
Shiftlcd Left                                           'shift the text to the left
Locate 2 , 1                                               'set cursor position
Lcd "*"                                                   'display this
Shiftcursor Right                                         'shift the cursor
Lcd "@"                                                   'display this
Home Upper                                                 'select line 1 and return home
Lcd "Replaced."                                           'replace the text
Cursor Off Noblink                                         'hide cursor
Cursor On Blink                                           'show cursor
Display Off                                               'turn display off
Display On                                                 'turn display on
Thirdline
Lcd "Line 3"
Fourthline
Lcd "Line 4"
Home Third                                                 'goto home on line three
Home Fourth
Home F                                                     'first letteer also works
Locate 4 , 1 : Lcd "Line 4"
Wait 1
Deflcdchar 1 , 225 , 227 , 226 , 226 , 226 , 242 , 234 , 228       ' replace ? with number (0-7)
Deflcdchar 0 , 240 , 224 , 224 , 255 , 254 , 252 , 248 , 240       ' replace ? with number (0-7)
Cls                                                       'select data RAM
Lcd Chr(0) ; Chr(1)                                       'print the special character
_temp1 = 1                                                 'value into ACC
!rCall _write_lcd                                           'put it on LCD
