CONFIG EVENT_SYSTEM
Top  Previous  Next
This statement configures the Xmega event routing.
CONFIG EVENT_SYSTEM = dummy, MUXx=MUX, QDx=QD, QDIx=QDI, QDIRMx=QDIRM,DIGFLTx=DIGFLT
The letter X is used to indicate that a value between 0 and 7 can be used. So there is MUX0, MUX1, MUX2,MUX3 etc.
The Event System is a set of features for inter peripheral communication. It enables the possibility
for a change of state in one peripheral to automatically trigger actions in other peripherals.
The change of state in a peripheral that will trigger actions in other peripherals is configurable in
software. It is a simple, but powerful system as it allows for autonomous control of peripherals
without any use of interrupt, CPU or DMA resources.
There are 8 multiplexers and 8 control registers. Register 0, 2 and 4 can be used for quadrature decoding.
MUX
There are 8 multiplexers, named MUX0-MUX7. The MUX is used to select an event source.There are many sources for events :
NONE : disabled, default
RTC_OVF : Real Timer overflow
RTC_CMP : Real Timer compare match
ACA_CH0 : analog comparator ACA, channel 0
ACA_CH1 : analog comparator ACA, channel 1
ACA_WIN : analog comparator ACA, window
ACB_CH0 : analog comparator ACB, channel 0
ACB_CH1 : analog comparator ACB, channel 1
ACB_WIN : analog comparator ACB, window
ADCA_CH0- ADCA_CH3 : ADCA channel 0-3
ADCB_CH0- ADCB_CH3 : ADCB channel 0-3
PORTA.0 - PORTA.7 : PORT A pin 0-7
PORTB.0 - PORTB.7 : PORT B pin 0-7
PORTC.0 - PORTC.7 : PORT C pin 0-7
PORTD.0 - PORTD.7 : PORT D pin 0-7
PORTE.0 - PORTE.7 : PORT E pin 0-7
PORTF.0 - PORTF.7 : PORT F pin 0-7
PRESCALER1, PRESCALER2, PRESCALER4, PRESCALER8, PRESCALER16, PRESCALER32, PRESCALER64,PRESCALER128,PRESCALER256,PRESCALER512,PRESCALER1024,PRESCALER2048,PRESCALER4096,PRESCALER8192,PRESCALER16384 : The clock divided by 1,2,4,8,16,32,64,128,256 etc.
TCC0_OVF  : Timer TC0 overflow
TCC0_ERR : Timer TC0 error
TCC0_CCA : Timer TC0 capture or compare match A
TCC0_CCB : Timer TC0 capture or compare match B
TCC0_CCC : Timer TC0 capture or compare match C
TCC0_CCD : Timer TC0 capture or compare match D
TCC1_OVF  : Timer TC1 overflow
TCC1_ERR : Timer TC1 error
TCC1_CCA : Timer TC1 capture or compare match A
TCC1_CCB : Timer TC1 capture or compare match B
TCC1_CCC : Timer TC1 capture or compare match C
TCC1_CCD : Timer TC1 capture or compare match D
Dito for TCD0, TCD1, TCE0, TCE1, TCF0 and TCF1
QD
Enables or disables the quadrature decoder. Will only work on QD0,QD2 and QD4.
QDI
Enables or disables the quadrature decode index. Will only work on QDI0, QDI2 and QDI4.
QDIRM
Quadrature decode index recognition mode. This is a numeric constant between 0 and 3. Each value represents the 2 possible bit values for the two input signals. Will only work on QDIRM0, QDIRM2 and QDIRM4.
DIGFLT
Defines the length of digital filtering used. Events will be passed through to the event channel only when the event source has been active and sampled with the same level for a number of peripheral clock for the number of cycles as defined by DIGFLT.
The number of samples is in the range from 1-8. The default is 1 sample.
