Configures the direct memory access (DMA) channel of the XMEGA.
CONFIG DMACHx=enabled|disabled,BURSTLEN=bl, CHANRPT=chrpt, CTR=ctr, SINGLESHOT=ss, TCI=tci, EIL=eil,SAR=sar, SAM=sam,DAR=dar,DAM=dam, TRIGGER,trig, BTC=btc, REPEAT=rpt,SADR=sadr, DADR=dadr
In order to understand the various options better, we first have a better look at DMA.
Normally, when you want to transfer data, the processor need to execute a number of operations.
The BASCOM MEMCOPY for example will use processor instructions like LD (load data) and ST(store data) in a loop.
If you want to clear 32KB of memory you need at least 32 K instructions. This will consume time, and all this time the processor can not handle other tasks.
In a PC, you do not want to use the processor to be busy when you load a file from disk. The DMA controller will handle this. It can move blocks of memory between devices.
DMA Transaction
A complete DMA read and write operation between memories and/or peripherals is called a DMA transaction.
A transaction is done in data blocks and the size of the transaction (number of bytes to transfer) is selectable from software and controlled by the block size and repeat counter
settings. Each block transfer is divided into smaller bursts
Block Transfer and Repeat
The size of the block transfer is set by the Block Transfer Count Register, and can be anything from 1 byte to 64 KBytes.
A repeat counter can be enabled to set a number of repeated block transfers before a transaction is complete. The repeat is from 1 to 255 and unlimited repeat count can be achieved by
setting the repeat count to zero.
Burst Transfer
As the AVR CPU and DMA controller use the same data buses a block transfer is divided into smaller burst transfers. The burst transfer is selectable to 1, 2, 4, or 8 bytes.
This means that, if the DMA acquires a data bus and a transfer request is pending it will occupy the bus until all bytes in the burst transfer is transferred.
A bus arbiter controls when the DMA controller and the AVR CPU can use the bus. The CPU always has priority, so as long as the CPU request access to the bus, any pending burst transfer
must wait. The CPU requests bus access when it executes an instruction that write or read data to SRAM, I/O memory, EEPROM and the External Bus Interface
DMACHx |
There are 4 DMA channels numbered 0-3. By default these DMA channels are disabled. Use ENABLED to enable the channel. |
bl |
BURSTLEN Each DMA channel has an internal transfer buffer that is used for 2, 4 and 8 byte burst transfers. When a transfer is triggered, a DMA channel will wait until the transfer buffer contains two bytes before the transfer starts. For 4 or 8 byte transfer, any remaining bytes is transferred as soon as they are ready for a DMA channel. The buffer is used to reduce the time the DMA controller occupy the bus.
Options : - 1 : 1 byte burst mode - 2 : 2 byte burst mode - 4 : 4 byte burst mode - 8 : 8 byte burst mode |
chanrpt |
Channel Repeat Setting this bit enables the repeat mode. In repeat mode, this bit is cleared by hardware in the beginning of the last block transfer. The REPCNT register should be configured before setting the REPEAT bit. When using the CONFIG command, the compiler will handle this. Options : Enabled : enabled repeat mode Disabled : disabled repeat mode |
ctr |
DMA Channel Transfer Request Setting this bit requests a data transfer on the DMA Channel. This bit is automatically cleared at the beginning of the data transfer Options : Enabled : request transfer |
ss |
DMA Channel Single Shot Data transfer Setting this bit enables the single shot mode. The channel will then do a burst transfer of BL bytes on the transfer trigger. This bit can not be changed if the channel is busy. Options : Enabled : enable SS mode. |
tci |
DMA Channel Transaction Complete Interrupt Level The interrupt can be turned OFF, or be given a pritoriy LO, MED or HI |
eil |
DMA Channel Error Interrupt Level The interrupt can be turned OFF, or be given a pritoriy LO, MED or HI |
sar |
Source Address Reload The channel source address can be reloaded the following way: NONE : No reload performed. BLOCK : DMA source address register is reloaded with initial value at end of BURST : DMA source address register is reloaded with initial value at end of TRANSACTION : DMA source address register is reloaded with initial value at |
sam |
Source Address Mode The address can be altered the following way : FIXED : The address remains the same. INC : The address is incremented by one DEC : The address is decremented by one If you want to write to a PORT, for example to generate a wave, you would chose FIXED. But if you want to move a block of memory, you want to use INC so the the source address is increased after each byte. |
dar |
Channel Destination Address Reload The channel destiny address can be reloaded the following way: NONE : No reload performed. BLOCK : DMA destiny address register is reloaded with initial value at end of BURST : DMA destiny address register is reloaded with initial value at end of TRANSACTION : DMA destiny address register is reloaded with initial value at |
dam |
Destiny Address Mode The address can be altered the following way : FIXED : The address remains the same. INC : The address is incremented by one DEC : The address is decremented by one If you want to write to a PORT, for example to generate a wave, you would chose FIXED. But if you want to move a block of memory, you want to use INC so the the source address is increased after each byte. |
trigger |
Trigger Source Select The trigger selected which device triggers the DMA transfer. A zero (0) will disable a trigger. You can find the values in the datasheet. For example, EVENTSYS channel 0 would be 1. And EVENSTYS channel 1 would be 1. |
btc |
Block Transfer Count The BTC represents the 16-bit value TRFCNT. TRFCNT defines the number of bytes in a block transfer. The value of TRFCNT is decremented after each byte read by the DMA channel. When TRFCNT reaches zero, the register is reloaded with the last value written to it. When repeat is 1, this is the total amount of bytes to send in the DMA transaction. |
repeat |
Repeat Counter Register REPCNTcounts how many times a block transfer is performed. For each block transfer this register will be decremented. |
sadr |
Source Address This is the address of the DMA source. For example, the address of a variable. Or the address of a register. Use VARPTR() to find the address of a variable. |
dadr |
Destination Address The destiny address. Memory will be transferred to this address. |
After you have configured the DMA channel, you can start the transfer with the START DMACHx statement.
This will write the TRFREQ bit in the CTRLA register.
' (c) 1995-2011, MCS
' xm128A1-DMA.bas
' This sample demonstrates DMA with an Xmega128A1
$regfile = "xm128a1def.dat"
$crystal = 32000000
$hwstack = 64
$swstack = 40
$framesize = 40
$lib "xmega.lib"
$external _xmegafix_clear
$external _xmegafix_rol_r1014
'configure the systemclock
Config Com1 = 38400 , Mode = Asynchroneous , Parity = None , Stopbits = 1 , Databits = 8
dim ar(100) as byte, dest(100) as byte,j as byte ,w as word
for j=1 to 100
ar(j)=j ' create an array and assign a value
next
print "DMA DEMO"
config dma= enabled, doublebuf=disabled,cpm = RR ' enable DMA
'you can configure 4 DMA channels
config dmach0=enabled ,burstlen=8,chanrpt=enabled, tci=off,eil=off, sar=none,sam=inc,dar=none,dam=inc ,trigger=0,btc=100 ,repeat =1,sadr=varptr(ar(1)),dadr=varptr(dest(1))
start dmach0 ' this will do a manual/software DMA transfer, when trigger<>0 you can use a hardware event as a trigger source
for j=1 to 50
print j;"-";ar(j);"-";dest(j) ' print the values
next
end
