CONFIG DACx
Top  Previous  Next
This statement configures the DACA or DACB in the Xmega.
CONFIG DACx=dac, IO0=IO0,  IO1=IO1, INTERNAL_OUTPUT =INTOTP, CHANNEL=channel, TRIGGER_CH0=trig0,   TRIGGER_CH1=trig1, REFERENCE=ref, LEFT_ADJUSTED=adjusted,  EVENT_CHANNEL=event, INTERVAL=interval,  REFRESH=refresh
DACX
Chose either DACA or DACB. DACA is connected to PORTA. DACB is connected to PORTB.
dac
ENABLED or DISABLED. Chose ENABLED to enable the DAC.
IO0
ENABLED or DISABLED. Chose ENABLED to enable output 0. Each DAC has 2 outputs. When multiple outputs are used, the DAC is using S&H.
IO1
ENABLED or DISABLED. Chose ENABLED to enable output 1.
Intotp
ENABLED or DISABLED. Chose ENABLED to enable the internal output.
Channel
SINGLE or DUAL. If both outputs are used, you need to enable the second output with IO1.
Trig0
ENABLED or DISABLED. Chose ENABLED to enable the trigger of channel 0.
Trig1
ENABLED or DISABLED. Chose ENABLED to enable the trigger of channel 1.
Ref
The DAC needs a stable voltage reference. You can chose one of the following:
- INT1V. This will select the internal 1V reference
- AVCC. This will use AVCC as reference.
- AREFA. This will use AREFA as reference.
- AREFB. This will use AREFB as reference.
The output of the DAC can never be higher then the voltage reference. When you chose INT1V, the output is from 0-1V in 4096 steps.
Adjusted
ENABLED or DISABLED. By default the DAC output is right adjusted. You can left alight the result.
Event
The event channel to use for the event system.
Interval
The minimum interval between 2 conversions.
This is a value of : 1,2,4,8,16,32,64 or 128. The default in the register is 64. A value of 64 will give an interval of 64 clock cycles.
Refresh
The DAC channel refresh timing. This is the interval refresh time in DUAL channel mode.
Possible values:
OFF
16, 32, 128, 256, 512, 1014, 2048, 4096, 8192, 16384, 32768, 65536.
A value of 16 means an interval of 16 clock cycles. The default loaded is 64.
The DAC data register is available in the DACA0, DACA1 and DACB0 and DACB1 variables.
START , STOP
Config Daca = Enabled , Io0 = Enabled , Channel = Single , Reference = Int1v , Interval = 64 , Refresh = 64
Daca0 = 4095                                                 '1 V output on porta.2
See also the example xm128a1.bas from the samples\chips folder
