This option specifies the lower boundary of all arrays.
CONFIG BASE= value
By default the first element of an array starts at 1. With CONFIG BASE=0 you can override this default so that all arrays start at 0.
In some cases it is simpler that elements start at 0.
A constant named _BASE reflects the setting. You can not change the BASE at run time.
When you change this setting in existing code, you need to alter your code. For example when you used this code:
Dim a(10) as byte : a(10) = 10
And you set CONFIG BASE=0, it will mean that element 10 is invalid.
While in QB an additional element is created, this is not a good idea in bascom because it will require more space.
CONFIG BASE=0
Dim ar(10) as byte , j as byte
For j=0 to 9
ar(j)=j
